Ve pump problems i time help!!!
thank you all, i'll say this. your the most awesome people out there. i'm at a lose for words in this. i thank you kindly for the pump you have offered OFELAS, ITS A WOW. i do have tools, not special tools for this as i take it will take. I don't know many people in the carolina's moved here 4 yrs ago, from the west coast. and am so lost here i hate it. but here i am. As for my beloved 92 dodge. its been my best friend and alway did the job no matter what it was. i hope indeed the offer is true. ill owe you also Ofelas. hope it happens thank you all for your more the AWESOME help
As for re-call possibly i did post the s# and pump date# my dodge only has approximately 135k on it yrs back i had to let my car go and the truck was my ride. i cant get financing for nothing as the fixed income really suck, and things happened to destroy my credit (medical bills) for the most part. THANK YOU GUYS REALLY YOU ARE THE BEST
mknittle (05-13-2017)
Cummins Guru
Good news your injection pump is covered under the recall 605, incomplete means never done and no infinity on data plate then you qualify for factory reman pump at no charge.
The following 3 users liked this post by BigIron70:
Cummins Guru
I'd be pretty surprised if any Chrysler dealership will honor that recall. In all likelyhood they'll tell you that the pump is NLA and they can't/won't help you. I had a similar experience with a really simple 2000 Jeep Cherokee recall. $2 part was NLA and they wouldn't honor the recall.
If you can't make any of the previously mentioned pump options work out I wouldn't haul the truck to the crusher. They'll give you $100 for it. Consider selling it as is. If its not a complete rust bucket you should be able to get $1000-$2000 for it. Probably more if it is 4x4 and in decent shape. Take the money you get from it and buy a pre-1997 F150 or F250 with a straight 6 and manual trans. Parts sre cheap and plentiful. Junk yards are full of them. The 4.9 motor is reliable and easy to work on. Good luck with it.
I also wouldn't trust any dealer within a 100 mile radius to actually replace the IP on a VE engine correctly. If I had to do it I'd tow the truck into the dealer, let them "fix" the recall and tow the truck to someone that I know is competent to check/fix their work.
If/when the dealership jerks the OP around about the recall what is his best remedy? Chrysler corporate or some Govt. agency?
Michael Lu'Bow (05-14-2017)
Indeed.
Michael, get that truck to the nearest Dodge dealer ASAP.
They should have a barring tool, if not, 22mm socket and a breaker bar, wedge the handle on the frame rail & bump her. Show 'em how its done.
Keep us posted, hopefully a good resolution, if not, we can revisit your free VE, the offer is still on the table.
Cummins Guru
Anyone can read recall here
Recall #605 Diesel Fuel Injection Pump
Yeah, thanks, BI70. I actually called my local Dodge dealer, two days ago, on the pump in this second dodge I just got. Girl at the service dept. asks for the mileage currently on the vehicle, and the last 8 numbers and letters of the vin. Pump was replaced in 1994, she says.
I was kinda wondering, as the pump had no black paint or remnants of paint on it. It was actually the cleanest and shiniest piece in the whole engine compartment.
The following 3 users liked this post by bigragu:
All Ram will do is find a pump threw their supplier. It'll most likely be a reman pump. If they try to give you the run around about not being able to get the recall parts tell them to F-off and write you a check for the loss. That check will cover a good reman pump from a good shop. Don't back down at all about demanding the check. It's a federal law they must comply with.
BUT first and foremost, does your pump have the infinity symbol!?
Michael Lu'Bow (06-19-2017)
Now dodge #1, I have no clue. Will check on that for sure in the am
The following 2 users liked this post by bigragu:
Michael Lu'Bow (05-14-2017),
mknittle (05-14-2017)
thank you all, they have honored the recall so far. an appointment has been made for my truck. i shell keep this open tell it is repaired my chrysler. so you shell know that it has been done.
Cool man! Hope they get it fixed. My truck has a build date 3/92 on the cab sticker. I looked my pump over as best as I could. I saw no infinity stamp but the date code on mine is 184 if I'm reading the correct number on the tag. Fortunately(?) not part of the recall.
Just my $0.02 worth. I could be wrong and I frequently am.
Edwin
The following 2 users liked this post by edwinsmith:
Michael Lu'Bow (06-19-2017),
