Ve pump problems i time help!!!
Old May 9, 2017 | 04:47 PM
Michael Lu'Bow's Avatar
Unhappy Ve pump problems i time help!!!
here is the story: was driving my 92 dodge gen 1 5.9 diesel, about 60 mph. it sort of missed 2 times. then just took off at full go with out my foot on peddle. i could control it by turning off key to stop engine. till i had place to stop the truck. had it towed home. did some looking, and others told me thing but it still runs away. i live in calabash North Carolina. only said this because your in south carolina some place. any was about me i was a ase master tech. but was on cars not diesel's at all. i did check return springs, and now have top off the pump but everything looks good. So why is this happening?? i really need my truck its all i got and retired but i work on beach houses, and am losing my contract if i dont figure this out. can you help me..and no i cant afford a new pump for i live on disability, and little money. i do have pictures of it all if needed. thank you
Old May 9, 2017 | 10:46 PM
BigIron70's Avatar
Cummins Guru
Call a Chrysler dealership and give them the last 8 of your vin numbers. They can run a vin search to see if this recall applies to your truck. If it does and it hasn't been done then they will replace your injection pump at no cost to you since recalls never expire. Refer to Recall #605.
To: All Dodge Truck Dealers
Subject: Safety Recall #605 -- Diesel Fuel Injection Pump
Models:
This Service Requirement Applies to Both, Original Equipment and Warranty Replacement Fuel Injection Pumps on the Following Vehicles:
• ORIGINAL EQUIPMENT PUMPS: -- Some Late 1991 Through Early 1992 Model Year Dodge Ram Pick Up Trucks (AD-body) Equipped With a 5.9L Intercooled Turbo Diesel Engine (excluding warranty replacement pumps after May 11,1993)
• WARRANTY SERVICE REPLACEMENT PUMPS: -- 1991, 1992 and 1993 Intercooled Turbo Diesel Engine and a Replacement Injection Pump Installed Through May 11, 1993
The fuel injection pump fulcrum lever pin may break causing a loss of throttle control. To correct this condition, the fuel injection pump must be replaced.
Old May 9, 2017 | 11:01 PM
BigIron70's Avatar
Cummins Guru
There is another way to check your pump if data tag is still there.
Old May 9, 2017 | 11:02 PM
BigIron70's Avatar
Cummins Guru
Click on image to read.
Old May 10, 2017 | 04:02 PM
ofelas's Avatar
Mike,
If your truck is an auto, check the TPS hex shaft for binding where it goes into the VE top. Loosen the AFC cover plate screws a turn each & see whether the throttle linkage pops back.
Whether auto or not, check the pedal linkage and cable all the way to the VE linkage.
Eyeball the fulcrum pin, and if it seems all there, wiggle it side to side before proceeding with the recall.
You may also want to see if the fuel screw has its lock collar missing, and check whether the locknut is tight.
Old May 10, 2017 | 04:37 PM
bigragu's Avatar
Originally Posted by ofelas
Mike,
Eyeball the fulcrum pin, and if it seems all there, wiggle it side to side before proceqeding with the recall.
Good points. Curious- if the pump had been tampered with, and it does fall under the recall, is one SOL due to the pump tampering?
Old May 10, 2017 | 06:23 PM
DONT KNOW WHAT I'LL DO RIGHT NOW DEPRESSED FOR I HAVE NO MONEY FOR A PUMP. AND NO TRUCK MEANS NO WORK, I'LL LOSE ALL MY CONTRACTS OF WORK NOW. DAM IT ALL...
IF YOU LOOK REAL HARD AT THE LOWER RIGHT CORNER INSIDE PUMP SEE IT LOOKS LIKE A PIN TO SOMETHING STUCK IN THE GEAR AHD HOUSING
Old May 10, 2017 | 06:29 PM
Thank you all your the best
WELL TRUCK PART COST TO MUCH, POOR THING WILL END UP IN SO JUNK YARD, FOR A RE BUILT PUMP IS 1400.00 DOLLARS AT ROCK AUTO. I JUST DONT HAVE THAT KIND OF MONEY. I BARELY LIVE ON MY LITTLE JOB, AND S.S.I.. I SAY THANK YOU YOU ARE GREAT PEOPLE HERE WISH IT HAD BEEN SOMETHING ELSE. WORST PART WHERE IS THE PIN, OR PIECE FROM??
Old May 10, 2017 | 08:40 PM
BigIron70's Avatar
Cummins Guru
Shoot me the last 8 on vin and I can check if recall was done and mileage
Check Ebay? Buy it $695 or pay $34 per month. Just make sure whoever installs it knows what he is doing. Wish you were closer I have install many of them, here is info if you want to replace yourself.
Recall #605 Diesel Fuel Injection Pump
Ebay ads not allowed on DTR
Old May 11, 2017 | 03:18 PM
I understand being on a fixed income, but will not the loss of the truck cause you even more hardships? The cost of another vehicle will most likely be more then the cost of fixing the IP.
Perhaps there is a local 1st gen person who could help you out? If you were close to me I would be more then willing to give my assistance to get you back on the road.
Hard to say where that pin came from without tearing the pump down. There are lots of little pins and parts inside the IP...guess something failed and broke and that is the result.
Old May 11, 2017 | 03:19 PM
ofelas's Avatar
Where are you located Michael ?
Old May 11, 2017 | 04:34 PM
OKAY GO the vin# 337ke23c5nm517522 also the pump has no infinity sign on it and i believe it says# 168 i pray it falls in recall let me know and if it does what i need to do...thank
ALSO I LIVE IN SUNSET BEACH NORTH CAROLINA IN THE BORDER OF MYRTLE BEACH SOUTH CAROLINA
Old May 11, 2017 | 06:41 PM
ofelas's Avatar
Michael,
I have a good running pump that came off a 92 you can have if it gets you back to work.
I am too far too drive down/install right now, but if you can meet up with boeingguy (a NC member on here) for the install, I will ship it down to him.
You can PM me/boeingguy with your cell # if you wish.
Old May 11, 2017 | 06:44 PM
edwinsmith's Avatar
Michael,
If you can meet up with boeingguy (a member on here) for the install, I will ship it down to him.
I'll be happy to loan a barring tool if you need one.
Edwin
Old May 11, 2017 | 09:36 PM
MrFusion's Avatar
I'd be pretty surprised if any Chrysler dealership will honor that recall. In all likelyhood they'll tell you that the pump is NLA and they can't/won't help you. I had a similar experience with a really simple 2000 Jeep Cherokee recall. $2 part was NLA and they wouldn't honor the recall.
If you can't make any of the previously mentioned pump options work out I wouldn't haul the truck to the crusher. They'll give you $100 for it. Consider selling it as is. If its not a complete rust bucket you should be able to get $1000-$2000 for it. Probably more if it is 4x4 and in decent shape. Take the money you get from it and buy a pre-1997 F150 or F250 with a straight 6 and manual trans. Parts sre cheap and plentiful. Junk yards are full of them. The 4.9 motor is reliable and easy to work on. Good luck with it.
