VE fuel inlet fitting size?
Old Sep 20, 2010 | 09:43 PM
93Fury's Avatar
What is the size in AN? Thought maybe I could do a fp gauge at the inlet of the pump?
Old Sep 20, 2010 | 11:24 PM
SOOT4BRAINS's Avatar
Pod Boy (on hiatus)
I used a metric to an style adapter and put a 90 degree fitting on top of that and tapped the elbow for a fuel pressure gauge. Its kind of a tight fit and kinda a pain to take on and off but it works great.
There is a fitting similar to this available from vulcan but its tapped on the wrong side of the 90 so I just tapped a normal one. It barely clears the throttle lever and I actually had to trim it just a bit in a non-critical spot. But it flows well and never leaks even though I have had it apart several times. Plus I know what my fuel pressure is at the pump.
The fuel pressure line came from vulcan with that 90 degree bend already on it.
Old Sep 20, 2010 | 11:53 PM
JustRamIt91's Avatar
cool setup, i really like the tapped 90* idea ;-)
Old Sep 21, 2010 | 05:31 PM
BearKiller's Avatar
I admire the craftsmanship of the tapped elbow; but, could not the same thing have been accomplished with a JIC swivel TEE fitting ??
Old Sep 21, 2010 | 07:56 PM
MARF75's Avatar
enlighten me...What is a JIC fitting??
Old Sep 22, 2010 | 04:25 PM
Just In Case?>?
Old Sep 22, 2010 | 08:55 PM
93Fury's Avatar
This is exactly what I am after. What is the AN size?
Old Sep 23, 2010 | 08:12 PM
-6 is usual.
Old Sep 23, 2010 | 09:51 PM
93Fury's Avatar
Thanks, should be fired up again this weekend.
Old Sep 24, 2010 | 05:04 PM
Pod Boy (on hiatus)
the fuel line is -8 which is about 1/2 inch. the fuel pressure gauge line is -4 I think. -8 may be a little overkill but that's what the airdog comes with.
Old Sep 24, 2010 | 10:33 PM
BearKiller's Avatar
For those who may not yet be in the know :
JIC = Joint International Conference
AN = ARMY/NAVY
The fittings are exactly the same except that the standards of material and fit is somewhat stricter for the AN which may be used on aircraft.
JIC is plenty good for what we do and far better than the way most are plumbed from the factory.
The numbers, such as -4, -6, -8, and so forth denote sixteenths of an inch = NO METRIC HERE = GOOD OLD AMERICAN measurements.
Each number represents that many sixteenths of an inch; for example:
-4 = 4/16-inch = 1/4-inch
-6 = 6/16-inch = 3/8-inch
One of the main attractions of using JIC/AN is being able to remove and then replace lines without damaging the rubber line.
Another big advantage is the way many JIC fittings will swivel, thus allowing complex fittings to be attached in places that would be impossible to screw in a rigid NPT fitting.
Also, the swivel fittings permit the fitting to be "aimed" in any direction, 360* around the fitting, without that aiming having any effect on the tightness of the fitting in the threaded hole.
Plain old NPT fittings can be aimed, but it is a trade-off of either the fitting just not hardly being as tightly attached as would be best, or taking it another round and it probably not being mechanically possible to do so; it's either risk a drip or risk splitting the tapered female portion.
I hope this clears up some of the bewilderment of those that do not yet understand JIC and AN terminology.
Onemoparnut
Jul 2, 2013 01:06 PM
iamvandemon
May 4, 2012 10:05 PM
Dean Snow
Apr 18, 2010 06:19 PM
jmd025
Sep 15, 2008 10:04 PM
superdodge
Mar 25, 2008 03:34 PM
