VE fuel inlet fitting size?
Old Sep 19, 2010 | 04:08 PM
93Fury's Avatar
Anyone know?
Old Sep 19, 2010 | 05:54 PM
93flatbed's Avatar
The real size is something metric like maybe 12or14mm, BUT a 1/4' NPT (National Pipe Thread) fitting works. With some pipe tape and tightening it down. I have no leaks....yet. Good Luck
Old Sep 19, 2010 | 06:07 PM
BearKiller's Avatar
I thought the pump inlet was 12MM x 1.5
I thought the LIFT-PUMP outlet was the only 14MM x 1.5 fitting in the system.
The 14MM x 1.5 ??can?? be substituted with a 1/4-NPT in the absence of the correct fitting.
It is not the best remedy, but in several attempts can be made to work.
Old Sep 19, 2010 | 07:23 PM
The Lift pump output is M14x1.5 Bear, You're right.
The Filter head Inlet is M12x1.5
However I'm not sure what the Injection pump inlet itself is....
Old Sep 19, 2010 | 07:25 PM
jimbo486's Avatar
Correct. Injection pump inlet threads are 12mm x 1.5.
Old Sep 19, 2010 | 07:32 PM
JustRamIt91's Avatar
i would check the pipe tape often, fuels seem to like and eat away at that stuff, even though it is a compression fitting stock... mine leaks a little from around the tube, all will be fixed one day.
Old Sep 19, 2010 | 07:50 PM
GIT-R-DONE's Avatar
If your installing a fuel pressure gauge, doesnt it come off the lift pump, or does it go off the fitting for the fuel filter? And what size would that one be?
Old Sep 19, 2010 | 07:51 PM
You want to get pressure when it comes through the filter,
The bleeder screw on the filter head is 1/8 NPT and makes a perfect place to put the fuel psi gauge, easy as that. It's after the fuel has been filtered.
Old Sep 19, 2010 | 07:59 PM
BearKiller's Avatar
Only if it has been re-drilled or replaced with a Geno's bolt .
Old Sep 19, 2010 | 08:10 PM
Yes you're right, I forgot i used the bolt LOL.
Old Sep 19, 2010 | 08:15 PM
93Fury's Avatar
I have done away with the mechanical lift pump and the stock filter head. I just needed the to find out for sure what the correct fitting size was so I can plumb accordingly. Thanks for the help guys, progress on the dually will speed up now.
Old Sep 19, 2010 | 08:58 PM
Order all your fittings from Vulcan diesel. Fast shipping and cheaper than GDP
Old Sep 19, 2010 | 09:43 PM
BearKiller's Avatar
I buy all of my fittings from these guys.
They have the best prices and quality, plus they treat me right.
http://www.discounthydraulichose.com...ric_p/9068.htm
JIC/AN is the way to go.
Old Sep 19, 2010 | 09:56 PM
93Fury's Avatar
I was looking at the tapped banjo bolt on vulcan's site. Anyone used on of these on the VE inlet?
Old Sep 20, 2010 | 07:43 PM
Why would you want a banjo there? Go straight in with an AN fitting.
