Vacuum Pump.
Old Feb 13, 2010 | 06:01 PM
Bruce M's Avatar
Vacuum Pump.
What do you need to do to install a 93 Vacuum Pump and Power Steering Pump in a 90 Cummins non inter cooled engine?
I noticed the support for the VE Pump is in the way if the 93 is installed.
Does the support have to be cut to install the 93?
If so how?
Old Feb 13, 2010 | 08:34 PM
rebal's Avatar
pump ,oil line power steering pump and it should go I think the bracket still stays it just linkage plate in the way . cant quite remember
Old Feb 14, 2010 | 08:43 PM
sdstriper's Avatar
Vacuum/power steering pump assembly and the oil feed line. You should also get the vac/pwr steer pump support bracket from the bottom up. Otherwise you risk breaking the mounting ears off the vac pump.
coalburner_77
17
Nov 7, 2018 07:36 PM
jimbo486
May 8, 2016 06:07 PM
powerstrokin03
Mar 19, 2007 01:00 PM
amartinson
0
May 4, 2003 01:55 PM
