RamW350 dually |
05-28-2008 07:38 PM |
Just this past weekend I had to replace my long awaited bad power steering pump, meaning that the vacuum/power steering pump had to come off as an assembly. Ahead of time I ordered the exact vacuum pump to timing cover gasket you are needing from Cummins. I work at a Freightliner dealership and had a reliable parts guy there order me the gasket from Cummins. That exact part # is 3938655 and I had no problems with it not fitting when I went to reinstall the vacuum pump and new remanufactured power steering pump mounted on the back of it. Cleaned the back side of the timing cover mating surface up, front face of the vacuum pump mating surface, applied a coating of spray adhesive to the front of vacuum pump, and installed gasket as spot on accurate as I could as far as lining up the two mounting bolt holes with gasket. The above part # should be good to go for you. Good luck.
Salvy
