Upper A-Arm Bushing Question.
Old May 28, 2018 | 09:02 PM
B Miller's Avatar
I am going to change my upper A-Arm Bushings, Ball Joints, Lower A-Arm Ball Joints, Strut Rod Bushings
and Idler Arm as needed.
According to a Shop I took my truck to they said I needed these items at a cost of $1004.72 dollars plus two new front Tires not included in the Price!!
So My question is having some spare A-Arm parts I pressed out one Upper A-Arm Bushing and found that the A-Arm had one half sleeve welded to the A-Arm
and another sleeve 3/4 of an inch long fell out when the Bushing was pressed out.
Is the second sleeve welded to the A-Arm or loose as I found it?
Also when you press in the new Bushing do you spray the two metal surfaces with WD-40 or oil prior to pressing?
Old May 28, 2018 | 10:18 PM
I believe those bushing were an added strengthening for the upper A-arm and bushings and are a separate piece and should come loose, but having said that none of the A-arm's I have done have had that secondary sleeve....probably changed before and left off. But Once the old bushing are out I usually will lube up the bore and bushing outer surface with some engine oil...usually just some used stuff laying around...then press them in.
Old May 29, 2018 | 06:40 AM
Jim Lane's Avatar
I just paid $1456.00 about 6 months ago to have my front suspension rebuilt including new Moog springs,
It was worth every penny and I didn't loose any blood in the process.
Jim
Old May 30, 2018 | 01:38 PM
u2slow's Avatar
Dunno why people insist on having 'everything' done.
When I went to change the coils and shocks in my D250 5 years ago, all I found that was worn out was one lower balljoint, and one upper control arm bushing. Replaced those, greased everything else, and carried on. Tape measure alignment. Grand total was ~$300.
Old May 30, 2018 | 06:54 PM
Jim Lane's Avatar
Preventive maintenance,
I did it because I have almost 500,000 miles or half million on my truck and although most of the parts didn't need it I plan to keep this truck forever and I will not have to worry about a part breaking due the metal fatigue,
Our 5.9 weighs almost twice that of a small block truck engine.
Also this my primary transportation that I also use for work.
Jim
Old May 30, 2018 | 08:43 PM
edwinsmith's Avatar
Jim
I would say it weighs closer to 3 times a small block v-8.
Edwin
Old May 31, 2018 | 01:30 AM
u2slow's Avatar
Jim
I have the same requirements for my rides... but haven't quite notched those miles yet. I have to stop wrenching and buying parts earlier than most... not enough hours in the day and I'd be flat broke.
The big joints in the the 4000# front end seem to last quite well, IMO, with regular greasing.
Old May 31, 2018 | 06:10 AM
Jim Lane's Avatar
True, true,
Small blocks are about 575 pounds.
One problem is finding parts of sufficient quality worthy of being on my truck with all of the knockoff and counterfit parts on the market especially on the internet.
This is why I will not buy from the internet, I like to hold it in my hand to compare first.
EdmontonCanada
37
Feb 4, 2016 12:02 PM
studebaker
Jul 15, 2008 08:54 AM
Joseph H. Smith
Jul 25, 2007 07:31 AM
winner172
Aug 16, 2004 12:24 PM
