Turned my truck up.
Old Sep 24, 2006 | 05:52 PM
MiniC's Avatar
Turned my truck up.
I followed the directions posted here on the site. Smoke screw 2 turns cw, AFC diaphragm turned cw 120 degrees, power adjustment screw in 2 turns. The start wheel I only turned cw about a half inch. I am thinking I need to turn it some more. Drivability is 10 times better. EGT's top out around 875-900, I do have 4" exhaust from the turbo back, no muffler. Boost increased from 14psi max to 22psi max, lots more boost at part throttle. The truck isnt really smoking at all, not at idle, part or full throttle. Normal?
Old Sep 24, 2006 | 05:56 PM
Sounds like you can crank 'er up some more. Pull the AFC cone out again and make sure you have the deepest side forward. The star wheel is not a real sensitive adjustment, you need to make at least two turns to notice the effects.
It should never smoke at idle. A puff of smoke when you lay into the accelerator is fine, and a gray haze out the the pipe at full power is good.
Old Sep 24, 2006 | 06:24 PM
MiniC's Avatar
Back to the garage I go!
Old Sep 24, 2006 | 07:02 PM
wheelo90's Avatar
Quick question!
How sensative is the smoke screw with no other pump adjustments?
Thanks!
Wheelo
Old Sep 24, 2006 | 07:10 PM
G1625S's Avatar
Originally Posted by wheelo90
Quick question!
Thanks!
Wheelo
Who has no other pump adjutments? Seriously, with a stock pump, you'll likely notice a difference with about 1 full turn.
Old Sep 24, 2006 | 07:12 PM
MiniC's Avatar
Quick question!
Thanks!
Wheelo
Cant help you, I did them all at once.
Old Sep 24, 2006 | 07:17 PM
Andy505's Avatar
Quick question!
Thanks!
Wheelo
I turned my smoke screw all the way down, removing the jam nut. It is some noticeable power for sure, but thats all that done to the truck....so its still slooow. but definitely faster than before.
Old Sep 24, 2006 | 08:24 PM
MiniC's Avatar
So I did what you said, the star wheel would go no further then a hair less then a full turn? It seemed to bottom out?
Old Sep 24, 2006 | 09:57 PM
gman07's Avatar
Mine was like that too; pretty close to bottomed out from the factory.
Old Sep 25, 2006 | 09:52 AM
jrussell's Avatar
Yep, same here.
Old Sep 25, 2006 | 12:34 PM
Ilikebikes's Avatar
Wow, that is low. Is the pyro probe post turbo or pre turbo?
Old Sep 25, 2006 | 01:46 PM
MiniC's Avatar
Pre turbo. I do still have the 21cm housing, and as mentioned earlier a 4" exhaust from the turbo back. I really am in need of a 16cm housing and tighter converter. They are next on the list.
eodshawn
Jun 1, 2007 10:52 PM
53 willys
34
May 29, 2007 01:03 AM
jtjr77
May 9, 2007 10:23 PM
whereswaldo250
Jan 3, 2007 09:51 PM
hawkeye759
Feb 4, 2005 06:26 PM
