Turbo ?'s, got a spare...
Old Dec 30, 2006 | 08:59 AM
triton0708's Avatar
So my cousin gave me his WH1-C turbo off of his 1994 CTD. I still have my stock turbo on my 91.5. (I reckon it is a 21cm housing.) I am guessing his is a 12cm housing?? But it looks as if it has a wastegate on it. Can I use this, and if so, where and how do I hook up the wastegate???
If needed, I can take pics of his turbo, but I'm sure you guys can show me the light without them.
Thanks a ton, Jeff
Old Dec 30, 2006 | 09:07 AM
signature600's Avatar
There should be a hole in the compressor housing outlet to screw a fitting into, then run a hose to the wastegate.
If there's no hole, make one I don't have any pics handy, but I'm sure someone will chime in with some!
Chris
Old Dec 30, 2006 | 09:33 AM
gman07's Avatar
Another way to run the wastegate would be to tee off the intake port for the boost gauge, and run a manual boost controller (available on ebay for under $50). That way you could adjust at what boost pressure the wastegate will open.
The WHIC will spool quicker and has a slightly better compressor than your stock turbo.
Old Dec 30, 2006 | 01:07 PM
Unless there's something wrong with the WH1C, just swap the whole turbo on.
I like running the wastegate off manifold boost so it's not affected by air temp so much. I used a 5 foot piece of brake line under the engine for a clean look.
Boatnik
Nov 6, 2007 07:52 PM
04ctd
Oct 15, 2006 03:10 AM
Timmay2
Feb 2, 2006 12:19 AM
sammy340
Jan 6, 2006 04:43 AM
Jeremy Cusick
Jun 16, 2004 10:07 PM
