turbo compressor wheel not spinning?
Old Sep 20, 2007 | 09:15 PM
ryan10's Avatar
Well, i just installed an 89 turbo on my 93, and i took the compressor wheel and housing off my 93 and put it on. i torqued everything, but the compressor wheel does not spin freely and when you start the truck, the wheel does not spin?
what did i do wrong?
Old Sep 20, 2007 | 09:43 PM
rbrettctd's Avatar
Sounds like you either have something too tight, or the wheel is binding with the housing. Either way, run it long at all and youre liable to snap a shaft or ruin a wheel.
Old Sep 20, 2007 | 09:50 PM
ryan10's Avatar
the only thing i could have too tight would be the compressor wheel nut, correct? i used a torque wrench and did 135 inch pounds /12 and its about 11.4 ft lbs. does the nut on the end of the wheel spin with the wheel, or does that stay in one place when the wheel is spinning? how could the wheel be coming in contact with the housing? is there any way i could have the wrong wheel?
Old Sep 20, 2007 | 09:54 PM
ryan10's Avatar
My old turbo had the banks power pack. did this come with a larger compressor wheel at all? maybe this could be the problem? should i try the wheel off of the 89 turbo?
Old Sep 20, 2007 | 10:12 PM
ryan10's Avatar
was i supposed to swap the shaft that the compressor wheel sits on from the 93 also? the one from the 89 is in there.
Old Sep 20, 2007 | 10:13 PM
rlyons's Avatar
No if you used the housing off your turbo it should work. Sounds like you torqued it too tight. It just takes a little bit to bind it up. I would use an inch pound wrench for sure. The foot pound wrench is not sensitive enough. Make sure your housing is on straight and even. Check the wheel as you torque it and stop if it binds and doesn't spin free. Once you bind it up you will have to tap it back a little to free it up and then retorque it.
Old Sep 20, 2007 | 10:14 PM
rlyons's Avatar
No use the 89 shaft. Yes the nut will turn with the shaft.
Old Sep 20, 2007 | 11:39 PM
edwinsmith's Avatar
Did you slide the shaft out of the bearing at all? If you did there is a sealing ring that may have popped out and is now binding. I had a heck of a time getting mine back in so it could definitely be a problem.
Edwin
Old Sep 21, 2007 | 05:44 AM
ryan10's Avatar
its not the nut, because even with the nut off the shaft does not spin freely. its almost like the shaft is getting sucked into the coupling in the back and causing it not to spin freely? is there supposed to be a bearing back there?
Old Sep 21, 2007 | 11:42 AM
rlyons's Avatar
Like I said even with the nut off if you had over tightened it you will need to tap the shaft back gently to free it up again. The bearings are internal. Did it spin freely before you took it apart?
Old Sep 21, 2007 | 01:54 PM
ryan10's Avatar
yes, it spun freely when i took it apart.
Old Sep 21, 2007 | 03:23 PM
ryan10's Avatar
Ok, well i figured out what it was. there is a small washer on the turbo shaft, on the side that goes into the exhaust housing. this was getting sucked into the turbo and causing it to hang up. what is this washer on the shaft? i just pulled it off for now.
Old Sep 21, 2007 | 08:00 PM
rlyons's Avatar
Don't run it with that washer off, it is a sealing washer to keep the exhaust out of the turbo housing. You really don't need to double post just post in one place and it will bump to the top.
Old Sep 21, 2007 | 08:51 PM
ryan10's Avatar
OK, thanks. sorry about that, just needed an answer really quick. i had a weird ring on it, that curved out at the end and this was catching, so i just cut that end off and made it so the ring sits inside of the groove. its all back together now. thanks guys.
Old Sep 21, 2007 | 09:55 PM
rlyons's Avatar
You may want to get the ring off your original turbo and use it or get a new one because if the one you cut leaks it will ruin the turbo.
