truck wont start
Old Jul 3, 2010 | 09:47 PM
boostedve's Avatar
truck wont start
looked at a truck today and it has been sitting for about 2 years it will turn over fresh fuel and i pulled one of the valve covers off and the rockers are going up and down.. and i cant get it to start on starting fluid.. what eles should i try..
Old Jul 3, 2010 | 10:44 PM
dzl_damon's Avatar
were you spraying in the intake, or into the suction of the turbo with ether? I didn't get a wimper from my 89 by spraying in the suction eye of the turbo, but she barked to life when sprayed into the (disconnected) grid heater after she set a year with the fuel system drained and the IP replaced.
Old Jul 3, 2010 | 10:51 PM
boostedve's Avatar
i tried in the turbo at first then went right into the grid heater..
and still nothin
Old Jul 4, 2010 | 06:41 AM
KD93's Avatar
Easiest things first... check the fuel filter for water. And when you crank it, have someone put their nose to the exhaust and sniff. If you can smell diesel you're getting fuel. If you don't smell anything you aren't. If you smell a varnish-like smell, your fuel is bad and you'll need to drain the tank. Depending on how full the tank was when sitting, you could have all sorts of bad stuff in the tank. Water, dirt, algae, slime etc.
Old Jul 4, 2010 | 07:31 AM
Does it at least bark on ether?
Gut the shutoff solenoid and make sure the shutdown lever is full forward.
Old Jul 4, 2010 | 07:34 AM
BearKiller's Avatar
Genuine ether or just "starting fluid" ??
Also what Dave said.
Old Jul 4, 2010 | 07:55 AM
boostedve's Avatar
im useing new fuel and taken a new filter today with me i took the old one off and dumped it illl do the shut off thing also.. see what we get.. thanks guys..
oh and i got some good ether today..
rustydeeretech
Jun 16, 2010 09:41 AM
Stroked-Z
Oct 4, 2008 11:28 AM
qcstunter
Jan 9, 2007 04:10 PM
doodah
Dec 15, 2002 05:03 AM
Desert Diesel
Dec 5, 2002 08:53 PM
