Transmission swap
You need the 2nd gen engine adapter and starter. The flex plate will work but the 2nd gen has a reinforcement plate at the crank. I would highly recommend this as the lock up converter puts added stress on the plate.
I had 315/75R16 on my W-350 crew cab 12 years ago, when it was dead stock suspension wise which is basically almost a 35 inch tire.
There was very little rub when turning and hitting a bump at the same time.
Will a factory 47RH handle my power levels or will i have to beef it up? Currently with the current wheel setup I've got about 3-4" of clearance on the inner wheel well 285's might work in there but ill have to check it out.
The speedo screws into the T-case on a 4x4, and as you will be using the same T-case. There will be no problems with getting the speedo to work.
mknittle (09-26-2017)
I was actually able to slot the carrier bearing mount plate on mine and had enough slip yoke to make it work. I did get the shaft shortened later when I had it balanced and replaced the carrier bearing and joints.
I think the 4X4 has room also so that you don't have to redrill the crossmember mounting.
Cactus92 (09-23-2017)
I have never done that swap, but just looking at a 47 RH and an A-518 next to each other on the shop floor I was guessing the driveshaft length would be really close.
The extra length comes from the engine adapter. It's 1.125 deeper to accommodate the lock up converter.
bigwheels94
07-11-2008 03:10 PM
Treangen
63
07-07-2008 07:42 PM
