transfer case onto 2wd trans
Old Dec 30, 2014 | 08:13 PM
NE frmhnd's Avatar
How hard a swap is it? Just bolt on? Or do parts need changed inside? How much disassembly if so?
Old Dec 30, 2014 | 09:52 PM
patdaly's Avatar
Pretty sure you have to pull the trans completely apart, if I remember, the planetary is attached to the output shaft, so you are at the last part pulled when you disassemble the trans.
OTOH, it would be a good time to bulletproof it!
Old Dec 31, 2014 | 12:56 AM
NE frmhnd's Avatar
For $300 for an 80,000 mile transmission that was in a truck that was bought for the body, vs $2,000 for a rebuild, it'll have to get the shaft swapped and run as it is. Or just run it as a 2wd for a while.
Old Dec 31, 2014 | 06:05 AM
Angry Johnny's Avatar
If it's an OD 518 all you need to change is the OD unit. If it's a 3 speed 727 you'll have to change the output shaft and extension housing.
Old Dec 31, 2014 | 07:55 AM
patdaly's Avatar
DUH........ Why didn't I realize that?
Sorry NE, AJ is right, if it is the OD version, it is a straight swap for the OD unit.
wyododge
Aug 18, 2011 07:48 AM
fruitcakesa
Dec 9, 2006 07:44 PM
Racing_Joe66
Nov 24, 2006 10:46 PM
P.J
Jan 18, 2006 12:03 AM
