Transfer case exploded today
Old Aug 12, 2016 | 12:33 AM
manvstaco's Avatar
Guess I'm shopping around, it is a NP241DLD tcase, I know a lot of ppl like to upgrade to the DHD so I figured I would ask around and see if someone has one possibly sell
Here is what happened today on the freeway, front driveline did this maybe?
Old Aug 12, 2016 | 05:39 AM
wheelerfreak's Avatar
we first genners have the 205, hopefully they're more bullet proof.
Old Aug 12, 2016 | 05:56 AM
The NP-205s is a much stronger case.
I would have a NP-241 DLD and a DHD T-case or two in the shop, I would sell.
PM me if you would like.
Old Aug 12, 2016 | 07:39 AM
deere country's Avatar
Your t-case is specific to the rh trans, one from a manual or re trans will not work without changing the input into the t-case.
Old Aug 12, 2016 | 08:51 AM
deere country,
Just last week I saw a NP-241 DHD from a '95 47 RH 4x4 that had a broken T-case with the shorter input shaft that would not accept a '94/'94 NP-241 DHD I had pulled from a 47RH 4x4 truck as it had the longer input shaft.
Old Aug 12, 2016 | 10:34 AM
cougar's Avatar
This 205 didn't make it. Name:  IMG_0505_zpswqdp78kv.jpg
Old Aug 12, 2016 | 10:41 AM
twostep's Avatar
and the story to go along with that carnage?
Is that from the truck you here hit in, and totaled it?
Old Aug 12, 2016 | 11:04 AM
cougar's Avatar
Yep, my old 91.5. The transmission didn't fair any better. The front differential was shoved under the cab. The drive shaft acted like a battering ram. Even the rear diff was bowed.
Old Aug 12, 2016 | 11:16 AM
freight train's Avatar
Just seeing that pic makes my wallet cry. And it isn't even my rig. Sad day for sure!
Old Aug 12, 2016 | 12:19 PM
manvstaco's Avatar
I have another thread in this forum " Power loss at 60 mph" with more details, I was diagnosing this problem when the t-case exploded
Old Aug 12, 2016 | 10:37 PM
deere country,
Is their any chance you took a picture of this? You said shorter input shaft, I believe you meant shorter input coupler? So your 95 model DHD was more like the DHD from behind an re trans?
Old Aug 13, 2016 | 08:47 AM
I do have a picture of it.
They are both '94 / '95 DHD T-cases from 47 RH trucks with the PTO cover and the smaller tail housing that only comes on the '94 and '95 DHD cases or usually on the DLD cases.
Yes I meant the input coupler was shorter.
Old Aug 15, 2016 | 07:45 AM
j_martin's Avatar
Case all broken up and no spilled lubricant. I believe you found your power loss problem. Should have been able to smell that one coming.
Old Aug 15, 2016 | 05:37 PM
DodgeFreak's Avatar
It looks like it spilled fluid to me considering the top and bottom of the tcase is wet with oil not to mention the underside cab is wet also.
