trans temp sender
Old Jul 19, 2006 | 06:29 PM
wayne74447's Avatar
trans temp sender
how did you guys mount your sender on your trannys? I thought about putting it in place of the factory one, you know the one that causes the downshift when the tranny gets to like 800 degrees... *laughs* anyway just fishing for ideas..
wayne
Old Jul 19, 2006 | 06:40 PM
goodtyms's Avatar
I used a T inline just inches away from the factory sender, right betwen the tranny pan and engine oil pan.
Old Jul 19, 2006 | 10:35 PM
jrussell's Avatar
I removed the stock sensor and used that port for my tranny temp gauage. The stock sensor can just be zip-tied up out of the way (but leave the wires connected). The only problem I had was the probe was a little long for that port, so I had to get a couple pipe thread fittings to space it out a little. It works great.
Old Jul 19, 2006 | 11:15 PM
Micaiahfied's Avatar
what exactly does the stock sender do?
Old Jul 20, 2006 | 05:48 AM
Den's Avatar
Den
It's used in the overdrive stuff. It'll prevent OD if the temp is too high
Here's my setup
Den
Old Jul 20, 2006 | 05:03 PM
kennedy's Avatar
just wondering what kind of temps you guys are getting that have it mounted in the line at the stock probe location?
Old Jul 20, 2006 | 08:55 PM
jrussell's Avatar
I usually see 150-180 unloaded on the highway cruising at 70mph and 180-200 towing a 5k trailer at 70mph. Haven't had to pull any long hills yet so that loaded figure might go up some.
Old Jul 20, 2006 | 09:38 PM
DBF's Avatar
DBF
When moving in ambient temps around 90*, I see 170-180-190. When I stop, it gradually comes down. Haven't observed towing temps yet.
DBF
Old Jul 20, 2006 | 09:42 PM
Boatnik's Avatar
Yep, that's what I did too. I have seen 260* on a hot day towing and in a hurry.
Old Jul 20, 2006 | 10:00 PM
Begle1's Avatar
What is the max operating range for our transmissions? Anything over 240 is a red light?
Old Jul 20, 2006 | 11:45 PM
Bushy's Avatar
Patron Saint of 1st gens
DC says that the sensor will kick you out of OD and/or prevent the upshift into OD if the temp reaches 275*F at that point you are pretty much cooking parts...sorta deep fryin 'um so to speak. not cool at all...
pb...
Old Jul 21, 2006 | 08:51 AM
Boatnik's Avatar
If temps are getting to be a problem, >245* try running synthetic. The ATF looses it's lubricity and protection quicker as temperature rises above 245*. Synthetics will run ok at higher temps, plus they have less fluid friction which helps lower overall temperatures.
2500TurboDodge
Aug 10, 2004 10:06 PM
e2360
May 15, 2004 08:44 PM
Reelay
May 6, 2004 07:29 AM
apache
Mar 3, 2004 07:27 AM
country
Aug 18, 2003 08:14 PM
