Trans help needed
Old Jan 18, 2010 | 11:38 AM
lkvlawn's Avatar
Trans help needed
I have a couple issues with my trans that im looking for some help with. Truck is a 92 w350 dually automatic 4wd.
First problem: Truck wont go into o/d. This is kind of the least of my concerns as i've been reading that there are a few options to fix this issue.
Second problem: When i put the truck in Drive and take off it stays in 3rd gear. If i manually shift the truck on the column it shifts perfectly fine. Trans isnt slipping, fluid doesnt look to bad, but not the best. Any advice to solve this problem would be much appreciated.
Also, being new to these trucks i obviously dont know to much about them. Is there a difference between a regular Ram and a Power Ram?
Thanks
Old Jan 18, 2010 | 06:12 PM
Easy one first - a Power Ram is a 4X4, a Ram is a 2wd.
Read this for help on the OD issue: https://www.dieseltruckresource.com/...77&postcount=2
Starting out in 3rd sounds like a stuck governor.
Old Jan 18, 2010 | 06:48 PM
lkvlawn's Avatar
stuck governor? parden my noob question but what does that mean and what should i do?
thanks
Old Jan 18, 2010 | 09:11 PM
DNRCustoms's Avatar
Sounds like your gov lever on the side of the trans is stuck in the forward position. Had that happen to me once, The tv cable actually popped out of the end of it.
Dr. Smasher
14
Jun 17, 2012 10:46 PM
mbaker
May 23, 2011 10:50 PM
bdepedro
Mar 8, 2011 06:28 PM
Diesel_Storm
Jul 20, 2007 11:17 PM
