trans cross-member mod to run bigger exhaust?
so I currently have an MBRP "four inch" exhaust. well they claim it to be 4" but it is actually 3.5" and it is SUPER TIGHT to my t case and front driveshaft. enough so that when in 4wd and braking moderately, the front of the truck dives down enough to get the spinning driveshaft to touch the exhaust pipe, causing a hellacious noise.
so what I'm wondering: on the trans cross-member there is two removable "wings" that connect the cross-member to the top of the frame rail on both sides for extra support. are these super necessary? has anybody removed the one on the passenger side to allow room for exhaust clearance? like a 5" exhaust maybe? -Sean |
well I think the biggest question to ask here is why? a 4" straight pipe exhaust would more than support the mods you have in your signature line. anything bigger than that is extremely unnecessary, even with compounds and more fuel. my diamond eye kit is 4" OD and fits through that same space you're speaking of. took a lot of fitting and moving around and adding of extra hangers, but it doesn't rub.
I would work on the fitment before removing cross-member braces. just my .02 |
You will not flow more exhaust than your turbine outlet size. All going bigger does is change exhaust noise.
That said, I had a Diamond Eye 4" on my old W250. It fit with a bit of room. I have seen others claim it doesn't fit but when you look at the trans rubber mounts, theirs were near nonexistent. I had good rubber isolators. This helped get the transfer case away from the frame rail. My theory on those wings. They help incorporate the whole frame rail height to help support the trans and transfer case. If you were to remove them, you'd only use that lower lip really to support all that weight. If you built another but used a plate that bolted outboard of the frame, the height of the frame with a tube to tie them together, you can eliminate them. This pic shows something for being inboard on the frame. https://cimg6.ibsrv.net/gimg/www.die...4b3c41fb46.jpg Hope this helps. |
Click on the following link for a couple pics of modded crossmember to allow exhaust pipe route through... '85 W350 Cummins Crew 4xDually - Dodge Cummins Diesel Forum
I have that MBRP exhaust pipe as well on a 4x4.
Some creative tack welding & a slightly shaved clamp did the trick with zero rubbing. |
Originally Posted by dieselJon
(Post 3283959)
(Post 3283959)
That said, I had a Diamond Eye 4" on my old W250. It fit with a bit of room. I have seen others claim it doesn't fit but when you look at the trans rubber mounts, theirs were near nonexistent. I had good rubber isolators. This helped get the transfer case away from the frame rail. My theory on those wings. They help incorporate the whole frame rail height to help support the trans and transfer case. If you were to remove them, you'd only use that lower lip really to support all that weight. If you built another but used a plate that bolted outboard of the frame, the height of the frame with a tube to tie them together, you can eliminate them. This pic shows something for being inboard on the frame. https://cimg6.ibsrv.net/gimg/www.die...4b3c41fb46.jpg Hope this helps. This question is based on waning to twin turbo and wanting to go 5" when I do so |
Originally Posted by DOZENVALVE
(Post 3284440)
So, that picture of the crossmember, is that for a dodge and available for purchase??? It looks awesome... I could always make something too I guess...
Originally Posted by 1972RedNeck
(Post 3284435)
I can't really prove it, but I think you are wrong here.
(Post 3284440)
(Post 3284500)
The most powerful guys in the sport go no bigger than 5 or 6" because that is what the turbine outlet size is. If there was an advantage, I'd bet they'd use it. The guys running triples I have seen have 2 4" exhausts dumping into the atmosphere OR collecting into a single 5". One of these trucks tows. If there was an advantage, I would think he'd use it.
(Post 3284634)
Wait, are you talking about the outlet size of the turbine housing or the turbine itself?
(Post 3284661)
The outlet of the housing.
(Post 3283933)
Originally Posted by jtamulonis
(Post 3284835)
I`ve eliminated the two "wings" on a few (at least 20) Chevy and that many Dodge trucks over the years NO PROBLEMS. Chevy quit using them in the early / mid `70s. dodge a little later. the only thing I noticed was that Chevy used longer bolts (about 1&1/4") with thick walled spacer tubing to hold the cross member to the lower frame flange. they also did the same to the bolts that hold the steering box to the frame. the longer bolts can stretch easier than the real short ones that they used to use. and the longer bolts stay tight and the real short ones would always come loose.
good to know! I may go ahead and delete them when I decide to go 5" everything. if it doesn't seem to have the strength ill just build custom. thanks |
