TPS Help please!
Old Jan 4, 2009 | 04:47 PM
2muchtq's Avatar
TPS Help please!
My TPS is bad... I think.
When I un plug the TPS itself, I have 5.32 volts on the wire closest to the cab... 1 volt to the wire in the center and 0 on the wire towards the radiator. This is with it NOT plugged in and taking readings off the plug.
With it plugged in I get 0 at 'idle' and .22 vlts @ full open throttle.
Is it the TPS or is there another problem somewhere?
Thanks
Mark
Old Jan 4, 2009 | 05:15 PM
keith1992's Avatar
It could just need cleaned. Are you sure you have a good connection between it and your meter? Mine was acting up when my OD problems started and while that was not my OD problem, it still needed cleaned. I sprayed it full of contact cleaner and then worked it back and forth several times, then put it back in its original position and it gave the right readings.
Old Jan 4, 2009 | 05:25 PM
2muchtq's Avatar
I've cleaned the holy hanna out of it.
Still no dice.
I am off to Auto Zone to see if I can possibly convert this thing to a 3.0 litre TPS off a dynasty.
35$ part vs 300$ sounds like it might be worth the effort.
Old Jan 4, 2009 | 05:40 PM
There's a link in the sticky about doing just that.
Old Jan 4, 2009 | 06:45 PM
2muchtq's Avatar
The dynasty TPS has a different plug.
Is there something I am missing?
Old Jan 4, 2009 | 06:50 PM
2muchtq's Avatar
Missed the 'need plug from gasser'
Anyone know if there is a part number floating around for the plug for this sensor?
Old Jan 4, 2009 | 07:46 PM
keith1992's Avatar
Or you can do the conversion to a potentiometer using Radio Shack parts.
Old Jan 4, 2009 | 07:48 PM
2muchtq's Avatar
I think having to kick out of OD manually would be a royal PIA.....
Old Jan 5, 2009 | 06:51 PM
Any auto parts store will have a pigtail that fits, it's a pretty standard weatherpack connector.
Old Jan 6, 2009 | 11:37 AM
Jet100's Avatar
With a potentiometer it kicks out of O/D Automatically... wherever YOU set it.
Old Jan 6, 2009 | 09:00 PM
dieselfortowing's Avatar
can somebody tell me how to do the potentiometer? i have seen seeral links but none have helped. i am havin problems with my '92 kickin out of OD
Old Jan 6, 2009 | 09:08 PM
Billut's Avatar
Go to the sticky, "How do I..." which is the first thread of the main page for the 1st Gen trucks, and go to the drivetrain title: the second thread is about how to replace the TPS with a potentiometer. I did it myself and did not even break a nail...
Old Jan 6, 2009 | 09:40 PM
92red's Avatar
I just did it over the Holidays. About $15 at Radio Shack and away I went. It made me giggle like a school girl when I got it dialed in and it worked so well.
Here ya' go:
Replacing the TPS with a potentiometer:
https://www.dieseltruckresource.com/d...ad.php?t=42003
Another writeup, but with pics:
https://www.dieseltruckresource.com/d...d.php?t=142641
The guy at RS very cautiously asked what I was doing with all my misc. stuff. As I picked my bag up off the counter I said "building a death ray!!" and just walked out the door. They might not let me in again, but it was worth it.
whosdunit
May 17, 2014 08:54 AM
SuperiorRam
Mar 15, 2007 03:10 AM
BigBully
Sep 28, 2006 06:54 PM
Dulley4x4
Jan 4, 2006 09:39 PM
IH8MYCAT
Feb 7, 2005 04:53 PM
