Tps ?
My dad's 93 CTD is ocassionally kicking back and forth between drive and OD.
Could it be the TPS or would it possibly be the trans temp sensor? I had this problem with the 95 and turned out to be the TPS. |
If the speedo is steady while this is happening, it's most likely the TPS. The temp switch doesn't kick you out of OD until things are way too hot.
Try adjusting the TPS, after Wanna tweaked mine it doesn't "search" anymore, and with the way it is adjusted right now at WOT it'll hold to 57mph before OD, but driving normal[dummy] it will shift into OD at 38mph
Life is good now[guitar] .... Thanks again Dave Michael |
