Tow mirror suggestions for my 92?
I have power side mirrors, but they really are not good for my towing needs- my horse trailer is way too wide for them. I need good wide tow mirrors. I am not married to the idea of needing power mirrors either. My 93 way back in the day had the tow mirrors, they came with the truck stock I think- it was a dually though.
They weren't the greatest looking things on earth, maybe there is something better now for our trucks? |
I use the tried and true stainless swing-out camper mirrors. They're from a Ford.
https://cimg4.ibsrv.net/gimg/www.die...3318a4b9e.jpeg |
My 81 came with something similar to that. I hated them because they always vibrated. I replaced them with West Coast trucker junior I think the where called. No longer made the last time I checked. They connected above and below the window.
https://cimg2.ibsrv.net/gimg/www.die...2342fb99ff.jpg |
If you want a project there's GM style or Ram "moose ears"
https://cimg5.ibsrv.net/gimg/www.die...3fa367b180.jpg |
Bigredbrick....that's an interesting bracket and mounting arrangement.....did you build those brackets yourself, or can you buy them? And those are the GM mirrors correct?
Control GM towing mirrors with Dodge dash controller? - Dodge Diesel - Diesel Truck Resource Forums
This is the thread on the mirror install. I'm still not done. I don't have a shop like some people! I'm going to move the support bracket inside the door forward, plug/weld up the holes and maybe a brace inside the door from bracket to ? if I can clear the window. Easiest way to go is a low mount set up which I think you can still buy. |
Originally Posted by u2slow
(Post 3383682)
I just use a set of CIPA slip on mirror extensions. They go over the stock OEM. I only need them when hauling hay or something else really wide that hangs over the gooseneck sides so I run stock 99% of the time and just slip them on & off as needed.
I put a flat bed on my M880 though and added the swingout type camper mirrors with the frog eyes like u2slow has. I like them but they do create a blind spot that you have to be aware of. Plus they catch branches & bushes if your driving in that type of terrain. |
One of the problems I find with the style mirrors u2slow has pictured, is they do not fit through my narrow garage door.
Might not be a problem for most, but it is something I have to think about. |
(Post 3383723)
(Post 3383723)
Might not be a problem for most, but it is something I have to think about. You can also loosen one bolt and flip them inboard; but that trick is useless if your bed/body is 7' wide or beyond. |
(Post 3383731)
I have a wide enough door, and just enough room between my 2-post lift columns.
Originally Posted by CruisingRam
(Post 3383792)
Any idea where to get the original flip tow mirrors like you have?
(Post 3383793)
Mine aren't original. They're stamped Ford. My primary part source is from parts-trucks.
https://cimg2.ibsrv.net/gimg/www.die...e419eff3bd.jpg |
