Torque rod, ladder bar?
well, I may have explained it poorly, but what mhuppertz sketched up in AutoCAD is what I was basically thinking about. He just took it one step further and made it into the so-named "upside down ladder bar" since he triangulated the mount to the lower part of the axle tube instead of just the upper, like the OP showed in his pic.
That will actually work better than the shackle, because the leverage or in this case "up" force (from axle twist) is spread across an effectively shorter arm. Get the forward gusset right up to the point of farthest travel into the the joint for the most strength. Otherwise it will fold at the gusset weld if you generate enough torque to do that.
Nevermind, it won't work. You have to remember the whole bar moves in the vertical plane with spring compression/decompression using a solid axle mount. You need a pivot on the axle mount, which would be negated by the slip joint. That's the advantage of the shackle. It will allow minimal up/down travel, depending on shackle length as it arcs back and forth. The slip joint doesn't allow any.
A traditional bar with solid attachments of any kind in either front or back is always going to involve some degree of bind because it has to move in two dimensions (a variable arc) in the vertical plane to track the springs. The trick is to find the right measurement, mount point and mounting pivot fitments to minimize that.
Nevermind, it won't work. You have to remember the whole bar moves in the vertical plane with spring compression/decompression using a solid axle mount. You need a pivot on the axle mount. That's the advantage of the shackle. It will allow minimal up/down travel, depending on shackle length as it arcs back and forth. The slip joint doesn't allow any.
DennisT
Jun 12, 2007 10:03 AM
Robert373
Apr 3, 2007 12:20 PM
BigBlue
Jul 9, 2005 11:50 PM
