tools for bump timing and grind foot
Old Mar 21, 2006 | 03:05 PM
puffmagicdiesel's Avatar
im planing on putting in gov spring and smokeys pin tommorow and i want to grind the foot lever. but what tools am i gonna ned i heard an s wrench to adjust timing but will a wobbler and a socket work, and do i need a dremel to grind the foot ive got an air powered die grinder with cutoff blades
Old Mar 21, 2006 | 03:22 PM
stillsmokin's Avatar
Ask wannadiesel about grinding the foot, from what I know that mod can put some serious fuel through the pump. I think most that have ground the foot are using a mildly shaved stock fuel pin.
Old Mar 21, 2006 | 03:23 PM
tboling's Avatar
Some basic tools like 13mm wrench for the 3 injector pump nuts. Allen wrenchs and a wrench with a wobble socket should work. A dermel or diegrineder will work just as well, have a small hammer on hand. Have a good pair of needlenose pliers for the gov spring and wacth that top hat another set of hands do come in handy. Hey while your in their is good time to replace the oring on the gov shaft to prevent future leaks. I aways put in a new brass sleeve and oring in the pump top. The bosch kit is only $22.00 Good Luck Tboling
PeytonMaterne
Aug 11, 2008 05:25 PM
aaronedwards82
Aug 26, 2006 04:42 AM
GR40RCapri
Jun 25, 2006 12:53 AM
puffmagicdiesel
Mar 26, 2006 09:35 AM
