Too many wires hooked to battery.
I must have at least a dozen wires going to each battery terminal. Has anyone seen a subpanel like what we use in buildings except for automotive.
It would be nice to just run a wire from the battery to a subpanel and then hook everything up to it.
Thanks
RonA
Thanks
RonA
Typical first gen is an electrical fire looking for a place to happen. Here's my solution to the hairy battery terminal. There's a row of breakers bolted to the inner finder to the left of the picture.
Trailer wiring likewise was a rat's nest. Here's my trailer wiring, fed by a fused 6 gauge wire going to the terminal in the first picture. Truck circuits feed relay coils, which switch fused power to the appropriate trailer circuit. This box is mounted in the frame under the cab.
here's another view of the 8 way connector, showing the heavy ground lug beside it.
here's a picture of the 8 point power block, available at Del City.
All to avoid this sort of scene. My friend's 2006 Chevy burned out by a well known heater wiring problem.
I need to get you to wire my truck! Looks sweet!
Yes, Blue Sea is a popular mfg of panels for marine and RV pplications.
Went down to the auto parts store just now and they didn't have anything. I'll put on my surfing attire and check out the internet this weekend and see if I can just order it online.
Guess when that blower motor stopped working on #5 he shoulda went off to the dealership to get if fixed for free under the special policy that he got a letter in the mail about?
I think there's gonna be a class action on this one, but I suspect Govm't Motors will duck out of it somehow. This regime gets the best court action money can buy.
Blue Sea fuse box
Try West Marine for the fuse box, Ron A.
The trailer wiring is neat and compact, J_Martin, but I would be wary of packing heat-producing relays in that pvc box without a vent. I would install a 3/4" fitting at the top of one side, (whatever side is facing the rear of the trailer), with mesh from a screen door where the cable would normally exit. That way you keep it cooler and critter-free.
Blue sea is what i am looking at.
http://www.amazon.com/gp/aw/d/B001P6...ing-goods?is=l
Sent from my DROID RAZR using Tapatalk 2
If I could find one with 4 circuits at around 30 amps each that would be about right. I need to run 2 FASS fuel pumps and a 30gpm water pump for the intercooler. That would leave me with a spare slot.
RonA
RonA
We build propane bobtail's at Arrow tank, and the control boxes usually have a couple of relays, a couple of solenoids, and usually a radio board. It's in a sealed PVC box smaller than that. Never had a heat problem.
