Timing question.
Figure the math.
What is the radius of your timing mark from the center of the shaft?
PI R square. No Cornbread square, pie round.
Distance around divided by 360. 1/8 = .125.
A SWAG, but I'd say close to 1°.
I was going to say it depends on the internals of your pump. I've had a few trucks that the standard 1/8" on the pump flange took me from ~1.4mm to 2.0mm. Others have moved from 1.25mm to 1.5-ish with 1/8". Like IRoss said, a gauge is not expensive, and worth it to know EXACTLY where you are.
The question of degrees of timing on the VE's has been asked online on various sites many, many times with no real good answer. I believe it is not possible at this point to determine a degree of timing with the VE like you see for the inline pumps. It is because the VE is in a constant variable state of timing depending on case pressure etc.
Honkylips
Oct 15, 2007 07:07 AM
GR40RCapri
Jun 25, 2006 12:53 AM
West Coast
Mar 26, 2006 11:09 AM
RonP
Feb 24, 2006 02:12 PM
