Timer for block heater: How long?
Hey folks,
Just wondering how many of you use a timer for your block heater and how long you let it run? I leave the house at 7:30 and was thinking 5:00 might be a good time for it switch on. If I don't plug it in and it's ~20 degrees...I don't really get heat on the way to work...and that's annoying...but I ain't made of money, either! ;) |
I use a timer and have it set to start two hours before I leave and it's warmed up pretty good when I start it. (We've already had several nights in the teens).
I had mine set at 2 hours and that seemed sufficient.
I run mine for 4hrs, but you know how warm it gets in the winter here.
i ran mine for 1.5 hours this morning (single digit temps but out of the wind) and the temp gauge had moved up. thats about all i ask out of it.
I just got a little timer at ACE hardware so i'm gonna start using it, but 2-3 hours should be enough
i bought one too for the block heater. it was something like 16 dollars but the gf has christmas tree lights hooked up to it[duhhh]
Block Heater
Set mine to turn on about two hours before start up. Also I throw a moving blanket,from harbor freight couple bucks, on top the motor. Really made a difference. Before the block heater,alone, would melt the snow off the hood. It also helps warm the battery,auxility fuel filter. Try not to forget it. I've drove a couple miles to work until I remembered it was still covering the engine. Luckily it is stiff enough to stay out of the belts.
Originally Posted by 92smokin blacky
(Post 2890062)
This is something I should look into. I left mine plugged in all day today for no reason. |
2 to 3 hours is all we ever ran them up here in northern NJ. We have a water heater timer setup to turn it on/off.
Not sure what I'm going to do this winter, truck's in a detached garage for the first time, warmer than outside, but I might set a timer for an hour to see if I get heat faster. |
Don't the block heaters turn themselves off when they reach a desired temp? and back on again when needed?
Originally Posted by rammin sammy
(Post 2890108)
I usually only do 1 hour but I will do 2 hours when its below 10 or so. |
Mine really makes the coolant sizzle. You can really hear it.
(Post 2890108)
I hear this all the time from people that should know better; it's sort of like the "full-time" 4x4 systems that "kick out at 30-mph." No; there is no thermostat of any kind on a standard block-heater. They are a simple water-heater element molded into an expandable rubber freeze-plug. :) |
i agree on 2 hrs. look at the specs on the timer you buy, some are not rated for over 600 watts. some are rated at 1500 watts. i dont know how many watts our block heaters draw but my stupid ( sold ) 6.0 powerstroke had a 2000 watt draw and fried a few timers...
anybody know the draw? |
| All times are GMT -5. The time now is 05:20 AM. |
