Three Wire Tranny on '93
Old May 15, 2008 | 09:15 AM
Tuckerdee's Avatar
Speed sensor, or VSS, is at the rear of the transmission, driver's side, above the cross member on a 2wd. It is also 2 wires.
Old May 15, 2008 | 09:23 AM
Camp10's Avatar
Woops, sorry for the confusion. I should check my service manual closer next time!
So I have a three wire VSS? Was this used with cruise control trucks? What confused me was the two wire VSS on my dad's '92. Thanks for the clarification everybody.
Old May 15, 2008 | 09:43 AM
Tuckerdee's Avatar
You should have three separate connectors. 1)Transmission O/D - it points straight up on the driver's side - it *should* have 2 wires - it's a weather-pak style connector 2)Neutral safety switch - it points to the left and back a bit on the driver's side - it's just below the shift linkage - it has 3 wires- it's some funky connector, not a weather-pak style 3) VSS - it's at the rear on the driver's side and points towards the left - it connects into the VSS itself which is sort of a squared oblong ovally thing - it has 2 wires - this is a weather-pak style as well. It's physically smaller than the O/D connector.
I just had all this mess apart last month. But of course I don't have any pics of the wiring connectors.
zachv
Dec 15, 2010 11:36 AM
$oC@l CTD
Jul 18, 2007 11:41 PM
robox
Apr 15, 2007 08:01 PM
TPilaske
16
Nov 22, 2002 08:15 PM
