Three Wire Tranny on '93
Old May 14, 2008 | 01:37 PM
Camp10's Avatar
Yesterday I noticed the overdrive solenoid on my A518 has 3 wires coming out of it. What gives? Do I have an OD section from a gasser? The wire colors are: orange/white, black/blue, purple/yellow.
The build sheet for the truck says A518, and it surely is not a lock-up tranny. Any ideas?
Old May 14, 2008 | 01:41 PM
NYCEGUY01's Avatar
When I talked to a couple tranny shops on my project they all told me that it was very possible that some 93's had a lockup trans. Both shops told me that they had seen them in person.
Old May 14, 2008 | 01:49 PM
Camp10's Avatar
The funny part is the tranny does not exibit lock-up charactersitics. I have owned this truck for 8 years and since it had 30,000 miles on it. I always assumed it was the standard A518.
I was just getting ready for a converter and valve body upgrade for the tranny, now I am not sure what I have and what to order for.
Old May 14, 2008 | 03:23 PM
jjdiesel1990's Avatar
What month of 93' was your truck made?
Old May 14, 2008 | 04:58 PM
Tuckerdee's Avatar
Are you sure it's the O/D solenoid and not the neutral safety switch? I believe that switch has three wires...at least mine does. The neutral safety switch also controls the backups lamps...that's why three wires.
Old May 14, 2008 | 05:06 PM
Tuckerdee's Avatar
Is it he connector that points up, or the connector that point towards the rear (sort of) that you're speaking of? The connector that points straight up is the O/D solenoid.
Old May 14, 2008 | 10:21 PM
Camp10's Avatar
The connector plugs in on the driver's side of the OD housing. It plugs in toward the transmission, if that makes sense.
Last night I compared it to my dad's '92, definitely different.
Old May 14, 2008 | 10:24 PM
user name's Avatar
Speed sensor? can't remember been a while since I've really looked at one
Old May 14, 2008 | 10:40 PM
Camp10's Avatar
Not sure of the month of manufacture. The last six digits on the VIN are 169886. Does that help?
Old May 14, 2008 | 10:44 PM
boostedve's Avatar
if it was a lock up couldnt you tell by the adaptor plate, wouldnt it be thicker to make up for the bigger torque converter..
Old May 14, 2008 | 10:46 PM
Trooperthorn's Avatar
You sure its not the sender for the electronic speedo?
Old May 14, 2008 | 10:48 PM
Alwaysworking's Avatar
alwaysonDTR
should be on the door jam sticker.
Old May 14, 2008 | 11:00 PM
Camp10's Avatar
The truck was built in June of '93. The wires I'm reffering to are about eight inches from the driveshaft u-joint, and plug in perpendicular to the driveshaft.
Old May 14, 2008 | 11:55 PM
Fred Swanson's Avatar
That's the speedo, not the trans OD connector.
Old May 15, 2008 | 08:04 AM
Caver Dave's Avatar
And to further add to the confusion...
When McMopar had mine opened up, he found the VB had everything machined & ready for a lookup TC... just no wiring (inside)/plug (outside) to get it signal!
