Thermostat Nightmares
Old Apr 2, 2008 | 12:44 PM
CaptainChrysler's Avatar
I know it's a little bit of a highjack but...
Is it worth upgrading to the 2nd gen bypass?
It bleeds air in the system, right?
My brother has a 98 and it seems to warm up faster.
Old Apr 2, 2008 | 08:15 PM
Boatnik's Avatar
What is a second gen bypass??? I've not worked on trucks that new very much.
Old Apr 2, 2008 | 10:38 PM
The link shows the hose. It goes from the t-stat housing to where the bleeder is on a 1st gen. There is a check valve/ nipple in the head.
Old Apr 3, 2008 | 06:48 AM
Exekiel69's Avatar
Due to the manner in which these thermostats are installed, it is an easy mistake to install one backwards.
I have had good results with my plain old Stant thermostat that was installed with no thought to jiggle-pin orientation; it warms to 180 and stays there, rock solid, up hill and down, loaded or empty, winter or summer, without the erratic gauge fluctuations that I see in most of the other 1st Gen./Cummins trucks that I have occassion to drive.
I, also, agree that Dodge was pretty stingy with the cooling system on these trucks; I could remove a section of my Ford radiator, equivalent to the size of the Dodge radiator, and still have more cooling than the Dodge.
I have good results with stant t-stat's in other applications, do You by chance have the part # for the one You have?
Thank You.
Old Apr 4, 2008 | 09:56 PM
Boatnik's Avatar
What link?
Old Apr 4, 2008 | 10:43 PM
http://dodgeram.info/tsb/1994/07-07-94.htm
Bookshelf
May 30, 2009 01:17 AM
notblowingsmoke
14
Nov 2, 2006 09:08 PM
HappyGA
Oct 30, 2006 12:35 PM
mechanic
Mar 25, 2003 08:45 AM
dart racer
Nov 11, 2002 10:10 AM
