Tallon Hydraulics HB kit pics
#61
This is as far as I've gotten today, and it'll sit this way, unfinished for a few days. The folks over at Tallon just made a slight boo boo and forgot to mail off my in line filter that I ordered last Thursday. Oh well, if this is their only fault, no big deal. I can tell that they're busy over there, dealing with the custom hot rod folks. Not gonna fault them for that mistake. Hopefully they overnight it.
So, in the pic, it shows the bench bled MC installed, brake stop switch reconnected, and the tie in of all vac lines, using a 3/8 x 3/8 x 1/4 tee fitting. Don't know if that accumulator get warm, so I anchored the vac lines to the firewall, keeping a safe distance.
#62
The stainless braided high pressure line from booster to steering gear unit, all installed. It's the one wrapped in the brightest blue. So, my only loose end, is the high pressure from the power steering pump to the booster.
I know a lot of the custom car folks like that stainless braided, for not only the longetivity of the hose(my first concern), but also a lot for the looks. Though I take pride in my work and do want the installs to come out pleasing to the eye, I always end up covering the stuff in loom, or wrap pieces of tubing as a way to prevent chaffing. Just when I think I have all hoses and tubing isolated from one another, I always, always come across some form of chaffing, which will eventually lead to hose failure. So I protect it. Maybe I'm wrong about this, but one of the concerns I had about HB conversions, was if I had a leak or a rupture from a faulted hose in the PS fluid system, what would happen while I was heading down a grade at high speed, and traffic came to a halt? No brakes and no steering! So, if any of you wonder if I've invested in the loom industry, there's the reason, LOL.
#64
Well, the install part, other than rebuilding the brake lines to the master cylinder, is actually not only easy, but kinda fun.
The hardest part, I believe, would be the sourcing of the components and fittings. If you like treasure hunts, then be prepared to do so, as others on here have. Looking back at the whole thing, now that I understand it better, I would definitely do what TCows did and reseal a junk yard find, and make it new again.
I've seen what type of projects you handle, Landen, you can definitely do this one.
The following 2 users liked this post by bigragu:
mknittle (04-29-2017),
thrashingcows (04-29-2017)
#65
Kinda embarrassed to say this, as less than a month ago I was preaching the word "SCEEERED"! I remember MKnittle being calm about this HB conversion thing, in his own way letting me know that it's really not that hard.
#66
That's right you did! My bad!!
#67
So is the conversion worth it. The work I mean. The reason I ask is because my brakes r the typical pump it ounce then u got brakes. I got other probs to but won't hijack the thread. I grew up with old fords and chevys and dodge trucks with no power brakes. So maybe I'm just used to it. Some body did bypass the abs stuff n the rear of my truck though. Gotta be careful when it rains. Lol
#69
I think I have around $200 into mine. $20 for a pick n pull booster, $20 for a reseal kit, $50 for a ton Chevy master cylinder and hoses and fittings.
#70
Dan, if you're a handy, mechanically, and tenacious type of fellow, in the words of The dude in Waterboy movie -" YOU CAN DO IT!"
I lack the tenacious part, and suffer from frustration not knowing which parts or fittings to get. That's why I opted for a pre made kit.
mknittle (04-30-2017)
#71
That's it Mark, rub it in, LOL!!
#72
Its not that i can't handle it, it's the matter of finding time to get it done!
thrashingcows (04-30-2017)
#73
If I do it I would just order the kit like u did ragu. But it will be down the rode a bit for me. I got a lot of other stuff to do first. (I ant starting my wife's house next week.). I got a garage first. Lol
#74
As far as saying if it's worth it, I won't know till I'm all done. I predict being done, with all bleeding and installs, by this coming Wednesday. Will let you know, then.
#75
