1st Gen. Ram - All TopicsDiscussion for all Dodge Rams prior to 1994. This includes engine, drivetrain and non-drivetrain discussions. Anything prior to 1994 should go in here.
I recently just bought a bone stock 1989 d250 as a work truck. The truck runs beautifully but the body is rough. The biggest issue I have st the moment is the drivers side tailgate hinge is gone. I have searched online and wasnt able to find a replacement. I was going to get some steel pipe and weld a new hinge up but would rather have the original hinge. Anyone know where to get one?
Check with Oliver Foster, a member here on this forum, he has one of everything, and two of everything else.
Great guy, very helpful.
I am sure I could find a thrashed bed, that I could cut a hinge out of.
Or you could weld one up. I have seen a spare socket used out of someones tool box before as well.
It worked pretty well. I can not remember the size socket used.
Thanks for the ideas. I think a socket would work better than pipe so I could get a better fit.
You're worried about fit? Oh Puleeze.
Seriously a piece of pipe the right size or slightly small will work fine. If it's a 1 ton, the drivers side hinge needs to be hollow for clearance lamp wiring.
