tailgate
Old Mar 23, 2013 | 11:22 AM
darkvader's Avatar
tailgate
The tailgate pin on the bed on the passenger side has gone missing. Are they available?. This is on the bed body and appears to be spot welded from the inside of the bed body to hold the pass side of the tailgate.
Clark
Old Mar 23, 2013 | 11:26 AM
93-12Smoke's Avatar
The latch pin?
Old Mar 23, 2013 | 01:23 PM
darkvader's Avatar
no. this is the oval pin that goes into the bottom of the gate to hold it on the truck
Clark
Old Mar 23, 2013 | 02:56 PM
dodgenstein's Avatar
I have made them from pipe mig welded to a piece of 1/8" flatbar, then mig welded to body.
Old Mar 23, 2013 | 05:01 PM
crazzywolfie's Avatar
i wonder if ones off a 87-04 f150 would work? i know they are suppose to bolt on.
Old Mar 24, 2013 | 09:12 AM
gyman98's Avatar
If you remove the tail light you can get at the backside
Old Mar 24, 2013 | 01:15 PM
darkvader's Avatar
need oval or rectangle for pass side as that side of gate needs to lift off pipe. Guess I will be making one. Plus 1 on removing taillight.
Thanks All
Clark
Old Mar 24, 2013 | 02:03 PM
maybe you could check your local junkyard for a 87-04 f150 and measure the hinge on it. might work. it might save you some time. i doubt a junkyard would want much for one since you can get them brand new for $15.
DORMAN Part # 38648
Old Mar 24, 2013 | 11:46 PM
ejblack0711's Avatar
Mine was missing to I welded a flat washer on to a pipe then welded that in the whole and just ground and filed on the welds until my tail gate fit and worked right its been that way for over a yr now and still going strong
Shovelhead
Aug 13, 2005 08:58 PM
spots
Feb 3, 2003 10:26 AM
ozzie
Jan 16, 2003 08:41 PM
BigBlue
Oct 19, 2002 01:07 PM
EricBu12
Oct 6, 2002 03:56 PM
