Tail Lights???
Old Feb 17, 2005 | 11:32 PM
440FURY's Avatar
Tail Lights???
fixed!!!!!!!!!!!!!!!!!!!!!!!!!!! Thanks!!!!!!!!!!!!!!
Old Feb 17, 2005 | 11:37 PM
edwinsmith's Avatar
Do you have a good 12v at the pin in the tail light bulb? If yes then check the ground connection of the light. If both lights are affected then you probably have a broken wire between the HL switch and the tail light. Do the front parking lights work? The marker lights?
Get out your volt/ohm meter and do some checking.
Edwin
Old Feb 18, 2005 | 09:51 AM
Alec's Avatar
Did you check the plug in the wiring harness under the tailgate/end of the bed?
Just a place to start looking.
Old Feb 18, 2005 | 02:05 PM
Nuttymopar's Avatar
I agree with both, check with meter. I always had just 10.5 V (if lucky) going to my rear lights until going with a 2 battery system. Much brighter now and easy to install the battery sideways in the stock location. I also had some bad wiring under the rear bed that I have taken care of with new wiring spliced in.
Old Feb 18, 2005 | 03:03 PM
440FURY's Avatar
Found it guys broken wire right before the rear harness took alot of hunting but got it solved thanks!!
cLAYH
19
Mar 26, 2017 06:47 PM
Troym61
Feb 11, 2009 01:48 PM
Patriot2500
Jun 25, 2008 08:47 PM
rdmartin108
Aug 19, 2007 08:06 PM
CHarlan
Aug 6, 2003 08:40 PM
