Swapping A DRW Dana70 for a Bad SRW DANA 70
Old Mar 23, 2011 | 12:43 AM
xjjones's Avatar
I am about to do this swap but want to double check with the experts..... (I am a long time lurker and reader of the sight but haven’t really posted before)
I have done a lot of searching and it appears everything works out …Right?
I have a 91.5 W250 and I am thinking about swapping the rear of a 92 w350 with the same gearing
Okay quick back story.....the special little lock clip on my the hub nut broke and everything backed off while going down the road.... extremely sucky.... worse part is that as the axle was ejecting itself it split the rear spindle in half...
My options
Junkyard axle I looked at the three junk yards in my area every Saturday for three week and couldn't find anything
Repair spindle by chopping it off and re welding all est. where in excess of a $1000
I called about 10 different salvage yards only found one axle back east and by the time i got it here it would be over 1000
Searched Craig’s list for weeks and came up empty handed. However found a plethera of dully axles... so i picked one up for 300
From what i read i will have to switch the wheel studs but that seems reasonable
The perches are in the correct spot
The axle is 6" longer overall ... that is 3” wider per side... however the original 91.5 W250 rear axle seats inboard by 2" in comparison to the front wheels on each side ... thus if i run a dully axle with the SRW it will sit 1" out from the front wheels and be barely noticeable and still within the fenders…. Right?
What else should i be concerned about?
Thank you for the help
Old Mar 25, 2011 | 11:30 PM
xjjones's Avatar
Old Mar 26, 2011 | 12:20 AM
Jer12377's Avatar
From: North Haven,CT "Living in occupied teritory" & Barton,VT
Im just guessing on this but, if it is your intent to keep it a SRW why can't you take the backing plates, for the brakes, off your old axle and transfer the the hubs with the drums to the DRW axle you are planning to use? A good friend of mine had an 89 Chevy DRW that did the same as yours did and the hubs and break parts were still usable. Then you are just using the housing and gears from the new axle and you don't have to mod the new one.
Old Mar 26, 2011 | 08:34 AM
Mark Nixon's Avatar
Actually, the folks that want to run the 3rd gen wheels on a 1st gen have put dually axles under their trucks to get the wheels to fit better, as they tend to sit too close to suspension parts on 1st gens.
In truth, a single wheel should still work fine, there's a lug nut out there that'll allow you to use your stock 3/4 ton wheel with the bigger axle studs and the wheel doesn't stick out beyond the bedside.
I don't believe the 3/4 ton hubs/backing plates will work on the 1 ton axle, due to bearing sizes.
Mark.
Old Mar 26, 2011 | 11:09 PM
feveree40's Avatar
Yep, should work fine to swap the entire axle. I ran a dually rear under my srw for a while and i liked the look of it much better. got the tires out to the edge of the bed instead of being tucked way in.
As far as hubs... yes, you will have to either switch studs or get new nuts. The drw and srw use the same wheel bearings, but the spacing on the hub is different. Even if you could use the srw hub, it would make the wheels stick out another 1" on each side.
The chevy rears are a little different. you can swap hubs and backing plates like i did when i put a 14 bolt under my dodge.
Old Mar 26, 2011 | 11:28 PM
xjjones's Avatar
Okay i think you guys have given me the motivation to do the swap.... I will let you know how it goes
Old Mar 27, 2011 | 07:37 AM
SlingShot's Avatar
Where are you located?
Old Mar 27, 2011 | 11:59 PM
xjjones's Avatar
I am in Corona, CA. Why do you ask?
somis13
May 28, 2013 12:36 PM
somis13
0
May 20, 2013 08:09 PM
89dieselkong
Apr 5, 2009 05:20 PM
powerrammaster
Feb 18, 2009 12:31 PM
dragginlx
15
Mar 9, 2007 11:32 AM
