Stuck in the sand
#31
Well the RPM's don't increase when trying to get over the 4x. So I figured it must be power
so I turned up the fuel screw 1 turn, now it can get over the 4x. I'll drive it around and see how it does on MPG's. Now the big question is what did Omega in El Cajon do to the pump that it lost that much power and MPG's. I just hope this fixes the problem.
I drive like an old man cuz I am.
#32
mknittle (04-10-2018)
#33
Mine was cranked to the max when I got it and it got about 18.5 MPG. When I replaced it with a stock tuned IP it still gets 18.5 MPG.
Edwin
#34
Up date on low MPGs & low power. Turned up the fuel screw 1 full turn and gained the power to climb over the 4x4 in the driveway. So now test driving it for the fuel problem. Driving it normally, the low fuel light came on at 276 mile, not a good sign. Filled up and figured the mileage, down by 1 to 11 MPG.
Well just a WARNING about where the work was done.
NTG Racing and Omega of El cajon. Neither one would stand behind their work to solve the problem. And don't come back.
Searching for the a solution. Thanks guys for all your help
Bill in San Diego
Bill in San Diego
#35
If the pump really is advanced from its original location (mark on pump closer to head of engine than mark on timing case), it is possible that the advance piston is jammed, or that the pump's pressure regulator is messed up.
It is also remotely possible that the fuel supply to the injection pump is restricted, but normally you would not notice this except at higher engine speeds where you would expect to see lower power and grey/white exhaust. Regardless, I would check for a clogged fuel filter, and kinked or clogged supply line from the filter to the injection pump.
#36
Bill in San Diego
Bill in San Diego
Clearly something is wrong but I wouldn't pin it on him or NTG.
I empathize with your frustration though.
#37
Is it possible the timing gear skipped a tooth or two in the retarded direction.
#38
Had the truck checked out at 3 other shops, the installation good & timing is advanced.
#40
Unless they pulled the timing cover to ensure the gear is timed correctly and has not jumped teeth, or used a dial indicator in the center plug of the pump head, they didn't actually check timing. The marks on the pump boss vs. timing cover mean nothing if the gear is not correctly timed.
The following 2 users liked this post by PapeCAT:
edwinsmith (04-26-2018),
mknittle (04-26-2018)
#41
Thanks
Bill in San Diego
CrazyFloyd
53
12-06-2007 11:45 AM
