Stroker kit for 5.9???
So i was readin the local classifieds the other day and Freedom diesel had a page with a bunch of stuff they have and they showed a stroker kit for a 5.9 cummins and said double your torque, make it equivilent to a 7.1!!! It said call for more info and pricing. I was kinda curious about this. I've never seen this, I was wonderin if anyone has done it or knows any more about it?
sounding like a snake oil type claim!
Strokin is cool though and does help, especially in gassers. IDK about diesels though. In Gassers they sometimes increase compression ratio at the same time which helps. But in a diesel, we sometimes need to decrease it since our boost pressures make up for it, and we'll break things otherwise. So the displacement is really the one big thing that would help.
I guess I can see where a torque claim would come from. Torque= Force X Moment Arm (length of lever you are pushing on) By increasing the stroke, you are making a crank shaft that has a greater swing (Moment Arm). So if your Force is the same (which most likely, it will increase a little as you have more displacement to boot), you torque will subsequentially increase too. I'm not forseeing DOUBLEING the torque though, as Wanna said.
If one looks at bore vs. stroke on the bigger engines. The STROKE is more than the bore... Its just a diesel thing, thats all. Big bore short stroke is great for a gas burner, not diesel. darn near all of big diesels are small bore, big stroke. Thats where the torque comes from.
In any engine when you stroke it and still use the same heads its gonna raise the compression. Maybe not much but it will raise it. Clearance volume will be the same but the total swept volume will be more. Hence swept volume vs. clearance volume gives you your compression ratio.
Ford 302 Engines (speed density engines at least) had a huge bore and tiny stroke and thats what made them so gutless when it came to torque.
I'm pretty sure diesels have a smaller bore, big stroke. = torque
Actua;;y the ford 302's 4" bore and 3" strole is a great combo. The heads were the downfall. Compare them to the longer stroke chevy 305??? I pull with alot of guys that stroke their tractors up to 4 inches, without a head, fuel and fire they are worthless. Just my .02
