steering shaft coupler
I'm replacing my steering shaft with the borgeson shaft. I have the shaft off but I can't get the coupler off! Is there some kind of puller or spreader that I can use? I really don't want to replace the gear too just because I can't seperate them!
Thanks, Rich
Thanks, Rich
I'm not really a moron!!!, honest I'm not. I can't beleive I thought that plastic plug INSIDE the pin was the pin! Thanks for your responses, ( I punched it out) ,now I must to my wife that she married a fool. Rich P.S. Is it a coincidence that I understood the instructions after I gave up for the day and have 3 beers in me?
Enjoy the Borgeson shaft, it was one of the best things I did. i was tired of driving like a blind man, drifting from side to side and bumping the steering to keep it in my lane. I racked up a million miles of tight steering on my shaft...
To hook up the rag joint do I re-use the two flat pieces again? I can't believe the column end connects to the material disc then the shaft connects to the disc with no real metal to metal bolt connections! Rich
You could replace the rag joint if you wanted, but as long as it's not obviously degraded - frayed, dry-rotted, whatever - I wouldn't bother. They are plenty strong enough for what they do, which is not much except provide a flexible connection to the shaft.
archer39
Mar 27, 2009 01:47 AM
redhornet
May 24, 2005 10:02 AM
