Steering Problem
Old Apr 13, 2009 | 03:13 PM
jmcentire's Avatar
Steering Problem
92 W250 - My truck will no longer drive straight, when you try to center the steering, it jerks to the left or right(depending on which way you are turning), and you can never get it centered.
I replaced my steering shaft since it had some play in it, so now I can at least keep control of the truck when it jerks.
Any ideas on where to start looking?
Thanks
Old Apr 13, 2009 | 03:36 PM
archer39's Avatar
time to jack up the front end and start looking for components with play in them.
Old Apr 13, 2009 | 03:42 PM
Charger's Avatar
Thanks
Mine was just doing that and it turned out the steering box was loose on the bracket that attaches to the frame. I tightened it up and it made a big improvement.
Regards,
Old Apr 13, 2009 | 04:12 PM
jmcentire's Avatar
Thanks! Hopefully tonight I can take a closer look at it. I'll let you know how it works out.
Old Apr 13, 2009 | 04:23 PM
dodgenstein's Avatar
Welcome to the site. Check for binding in the front axle u-joints also. Even if they aren't being rotated, they have to turn as you corner.
Old Apr 13, 2009 | 06:18 PM
tanyj's Avatar
I had the exact same problem with my old 1st gen. It turned out to be the axle joint on the driver's side.
LanceK
13
Jul 14, 2006 08:08 PM
ocsurf16
Mar 13, 2006 09:24 PM
unioncreek
Jun 29, 2005 02:00 PM
OHFarmboy
Feb 25, 2005 11:30 AM
Jun 5, 2003 09:27 PM
