Steering Alignment
Old 12-05-2017, 05:27 PM
GCam's Avatar
Steering Alignment
Hey guys, I brought my truck in for an alignment to get an idea of where it is at before I get new tires. They told me my camber is out on both wheels (blamed on axle sag?), as our front ends are non adjustable they suggest installing caster/camber kits. Is this the only way to go? Any suggestions?
They also said the toe was out on one wheel but that they could adjust that.
Thanks guys!
Old 12-05-2017, 05:41 PM
u2slow's Avatar
When's the last time the kingpins were rebuilt?
Aside from a bent housing or bent spindles, that's about all it can be.
mknittle (12-06-2017)
Old 12-05-2017, 05:44 PM
GCam's Avatar
I can't confirm that, maybe never.
I don't think both would be bent. The garages explanation of sagging axles, would that be due to wore out kingpins?
Old 12-05-2017, 05:49 PM
Received 1,637 Likes on 1,112 Posts
The cone and plastic cup can wear out, and I'm sure the lower bearing can as well.
Rebuild the upper and lower king pins, and take it back. the only thing you should need to have done is the "Toe" adjustment, and steering wheel centering again.
Look at Marks "okay, lets do our king pins", thread. Explains pretty much it all.
https://www.dieseltruckresource.com/...g-pins-290373/
Old 12-05-2017, 05:53 PM
GCam's Avatar
Is there a kit that includes everything that you guys would suggest?
Old 12-05-2017, 05:57 PM
u2slow's Avatar
The upper is a spring-loaded nylon cup that rides on a steel cone. The lower is a tapered roller bearing. Some guys have added washers to the upper in attempt to restore the spring tension and camber.
I'm still running on old tired kingpins, DIY tape measure alignment, and my tires (new 13 months ago) are wearing fine. YMMV.
I picked up new springs and cups from ORD to put in when I install my highsteer arm.
For a full kit, I saw rockauto carries USA32304.
GCam (12-05-2017)
Old 12-05-2017, 06:14 PM
GCam's Avatar
Thoughts on a caster/camber kit?
Old 12-05-2017, 06:17 PM
u2slow's Avatar
Shouldn't need one. If a std rebuild kit doesn't get results, start saving for a straight diff housing.
Old 12-05-2017, 06:18 PM
GCam's Avatar
Meaning mine could be bent?
Old 12-05-2017, 06:25 PM
u2slow's Avatar
Any diff can be bent. Not many are.
I don't know how bad the camber issue is. There should be none. I'd guess shimming or replacing the kingpin springs will correct it. Maybe change the cups too.
I don't trust what shops say anymore. I do all my own work.
Old 12-05-2017, 06:32 PM
GCam's Avatar
Fair enough, I try to do most of my own but figured I'd get the front end checked. I will post the Report.
Old 12-05-2017, 06:33 PM
GCam's Avatar
Old 12-05-2017, 06:46 PM
u2slow's Avatar
Its not a lot of camber, and only 1/2 degree of variance. Seems more typical, IMO, than concerning.
Jack up each front corner and see if the tire 'straightens up' when load comes off it. Can you rock the top of the tire in and out? These two things would point to some kind of kingpin wear/slop...
Old 12-05-2017, 06:49 PM
GCam's Avatar
I am out of town until Friday but will check the straightening and rocking.
How much camber would you be concerned with?
Old 12-05-2017, 07:57 PM
I would only use Spicer parts. I picked up a kit off eBay #
222065724894
From a different vendor, at the time
GCam (12-05-2017)
Quick Reply: Steering Alignment
