starting problem?
Thanks flashgordon but doesnt the lift pump have a quick connect for the fuel line? Or was I looking at something else? I was planning on hooking it up straight to the lift pump to make sure if there is a leak its behind the lift pump. But if there is a quick connect do I just use a regular hose clamp on the clear hose? To answer your question I am away from the truck. I plan on going to napa to pick up a new lift pump before going back in a couple weeks and see if that helps. If not I guess I will try the clear hose. Thanks again
Well a mine had a hose clamp on it but i remember some one saying....i thing it was dave that the 92-93 have a plastic line and if that's so then there will be a Quick conector......hmmmmm all i can go by as far as a Quick coneter gos is on the 2nt gen truck and if its the same them you will need a small pease of metal tube to put in the female sided then a clear hose between them
Yes, you have a quick disconnect. Undo the fitting and unscrew the adaptor from the pump, then go get a a couple of hose barbs and a coupler to put the barb on the factory fitting.
fourthandgoal
88
Dec 27, 2011 05:39 AM
abc4yew
Mar 15, 2007 11:55 PM
Palmetto_kid
Apr 25, 2003 05:14 PM
turbospl311
15
Jan 21, 2003 12:39 PM
