starters out
Old Oct 13, 2010 | 03:26 AM
NE frmhnd's Avatar
starters out
IT pretty well gave up on me the night before last. If I hit it hard enough it will start to grind, and after crossing the terminals a few times it will crank the motor up. NAPA will have a fresh one for me this morning. I think the high voltage issue I've been having may have been caused by the high draw from the starter going bad. The regulator is sticking. But otherwise it's got me from home to Belfield, ND, to McCook, Nebraska without any troubles.
I got a friend here with a pit in his garage that's going to help me swap the starter.
Old Oct 13, 2010 | 08:51 PM
pulltilbroke's Avatar
Best Paint (Getrag category)
Don't turn in the original for the core money, keep it and rebuild it. The originals seem to last a lot longer than the ones you get from an auto parts store.
They are really easy to rebuild also
Old Oct 13, 2010 | 09:00 PM
#2isgreen's Avatar
Unless it's untaxed, then it's red.
are you sure its not just a corroded starter wire? i think the stock starters are pretty tough. the jacketing can still look good the the wire will be puke green inside
Old Oct 14, 2010 | 07:34 PM
NE frmhnd's Avatar
I don't know, it was grinding when it turned. Being new out here in Nebraska I didn't really want to take the time to screw with it and got a rebuild from NAPA. Too late on the core, too. Then again, it's a choice between keep the core or have enough money to live another day right now. I have to find a job soon, got a couple offers, the first they seem a little too eager, and their trucks are fairly beat up, so I am going to take the second I think.
I was thinking of trying the Case dealer but figured it wouldn't match. Turns out it's the same starter the 580 Super M backhoe takes.
Old Oct 14, 2010 | 10:39 PM
Whered ya move from, I'm on the other end of the state just east of Lincoln.
Old Oct 15, 2010 | 01:28 PM
NE frmhnd's Avatar
From northwestern PA to McCook by way of Belfield, ND. Went to work for a harvester, but they lost about 1200 acres of milo and I got sent home. Got a few friends in this area so I came down here.
The Domie
Jan 24, 2005 06:08 PM
LanceD
Dec 18, 2004 09:45 AM
wheelin66
Nov 14, 2004 10:31 AM
newf
21
Aug 15, 2004 09:32 PM
dieselnewbie
13
Mar 19, 2004 10:08 PM
