starter problems
Old Feb 1, 2006 | 11:12 AM
ouchman's Avatar
starter problems
When I start my truck I always have to turn the key twice and it fires the second time. About every 20 or so times it does nothing. The guy I bought it from has a wire coming off the starter to right by the battery. He said "if it doesn't start, pop the hood and leave the key on and just touch this wire to the + terminal". YIKES. Ok - for the first time last night I had to actuall try this. Of course it worked, but crazy me, I think I'll just FIX IT THE RIGHT WAY.
The starter is new - anybody have any ideas what it might be? I am thinking it might be wiring in the steering column, but not sure.
Old Feb 1, 2006 | 11:42 AM
Geico266's Avatar
Try replacing the starter contacts first. Cheap $40. They sell heavy duty ones at Larry B's.
http://www.fostertruck.com/dodge/default.htm
See my pics for what they look like burnt.
Old Feb 1, 2006 | 11:45 AM
blueberry's Avatar
If you have a 5 spd, there is a clutch safety switch that can fail. I bypassed mine.
-brina
rebal's Avatar
it might be your ignition switch , i had that similar problem on my 90 a long time ago
Old Feb 1, 2006 | 12:49 PM
ouchman's Avatar
I am thinking at's the starter switch. As I said the starter is new so I doubt that's it. Any good places to get a starter switch?
Old Feb 1, 2006 | 03:13 PM
loch's Avatar
New or not, it can fail. But as was mentioned i would look at the clutch safty switch and ignition switch. If its not a tilt wheel the ignition switch is under the dash. The mounts are slotted and may just need a bit of adjustment. Its controlled by that rod runs down the steering colum. If its starting by jumping the solonoid straight to battery, tell me starters fine.
Old Feb 1, 2006 | 03:15 PM
It's either the ignition switch or a flaky starter relay. You can replace them both for under $50.
DJ Turbo.
Oct 13, 2011 09:11 PM
FMB
Nov 14, 2010 09:09 PM
12valvesmoke
Jun 12, 2009 09:46 AM
buckman361
Nov 13, 2008 09:54 AM
Paradise Racing
Jan 18, 2005 09:08 AM
