Started fixing cab leaks
Old 03-16-2019, 09:02 PM
Pulled passenger side fender today NO cab cracks at all after 1.1 million miles. I sealed a little rubber trap door on front of cowl and put new seam sealer along firewall seam. Will water test it tomorrow before reassembly and then tear drivers side apart which was leaking much worse than passenger side.
Im also using POR15 to paint any light rust spots. If u ever use this stuff, definately use rubber gloves as it doesnt wash off skin much at all.
mopar2ya is offline
The following 2 users liked this post by mopar2ya:
Diesel_Dawg (03-18-2019), nonrev (03-17-2019)
Old 03-18-2019, 09:21 PM
Diesel_Dawg's Avatar
That is great to hear. What year is your truck and are you the original owner?
I have often wondered if the shudder the Cummins powered trucks make when they are shut down contributes to the cowl cracks, especially if you shut it down with the door(s) open, since I rarely see the cracks on gas powered trucks of the same vintage.
Diesel_Dawg is offline
Old 03-18-2019, 09:27 PM
edwinsmith's Avatar
I think it's probably more prevalent in the 4X4 models because they go out rock climbing.
edwinsmith is offline
Old 03-19-2019, 07:08 AM
Received 1,142 Likes on 732 Posts
I had cowl cracks on both my 2wd gas power Ramchargers that both had under 100,000 miles on them.
Both my crew cabs, that are now 12V powered, had them too before doing the swap.
I find those cracks on most any 1st gen I work on.
oliver foster is online now
Old 03-21-2019, 05:59 AM
I must be the only one who doesnt have cowl cracks. Pulled the fenders off 2 years ago and was quite surprised, especially since my front cab supports are rotted.
peckens is offline
Old 03-21-2019, 05:10 PM
its a 1993 4x4. I pulled the drivers side fender today, which is the side that leaked quite a bit. NO CAB CRACKS. It appears water is coming through the floor vent kick panel. why it hasnt done this years ago is a mystery. but it seems like the water tension pulls it over the lip of the vent and then it dribbles down to the lower parts and leaks into the cab. So.
Any ideas on a solution to remedy this and keep the floor vent working?
mopar2ya is offline
Old 03-21-2019, 07:32 PM
edwinsmith's Avatar
Check for leaves etc... in the vent. I know that stuff gets in the other side and fills up the heater box in front of the A/C evaporator.
Old 03-21-2019, 09:31 PM
I use adhesive backed foam tape to replace the deteriorating OEM foam gasket on (3) of my trucks to stop the leaking.
Old 03-22-2019, 04:39 PM
Heres a couple of pics. Wouldnt it smart if the rain gutter above the plastic scoop went all the way across so water didnt pour on the scoop?
mopar2ya is offline
Old 03-23-2019, 07:20 PM
NO MORE LEAKS!!! I did a couple things. 1-resealed floor vent with new foam. 2- added a ring to the floor vent inlet to stop any water that leaks inside scoop 3- put a splash shield above the inlet to stop cowl water from dropping on inlet vent. Here are pics and a youtube link I did.
​https://m.youtube.com/watch?v=MKjx9sxWSbg​​​​​​
mopar2ya is offline
92'1stGen
03-19-2018 12:16 PM
bannerd
03-03-2014 05:52 AM
abchoppers
01-26-2011 05:38 AM
ADMOPARMAN
07-10-2010 12:59 PM
samiam4
03-19-2009 10:24 PM
Quick Reply: Started fixing cab leaks
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
