Squeak squeak squeak...
Old May 8, 2007 | 03:39 PM
gman07's Avatar
Red face Squeak squeak squeak...
I have recently aquired a squeak in my truck, but only in gear... It's vehicle speed related, not engine speed. I noticed it when backing up (it does it going forward too though), and as soon as I took it out of gear and started coasting the squeak quit. I'm going to see what I can figure out in a couple minutes when I go put my tailpipe back on (), and I'd appreciate any suggestions. I'm thinking maybe a bearing in the rear differential, but I'm not sure. I have absolutely no experience with differentials, so you'd have to walk me through what each part is like a noob. I'd like to do this myself if possible. My only other thought is some part in the transmission.
Luckily I just got my first year of college paid for through a scholarship so I'm not completely broke.
Old May 9, 2007 | 06:03 AM
DISLSMOKE's Avatar
You could have a u-joint in your drive shaft going south. Do you do heavy pulling, or burnouts? I would check and see if you have any movement in your drive shaft (get under the truck and shake the bejesus out of it). A tight joint will squeak also.
shep1
Aug 29, 2010 10:19 PM
CTD2001
15
Nov 28, 2009 07:54 PM
06RED-BARON
ABDTR #5
20
Jul 2, 2009 10:54 PM
ytodd
Nov 2, 2007 09:57 AM
hotdram
31
Sep 17, 2005 08:00 AM
