spooling HX40 with stock injectors?
Old Feb 25, 2008 | 10:01 PM
krazykarl454's Avatar
i know this is a NOOB question but i need to know stat. cause i need finish my truck and get down to nc stat
hey guys, im in abit of a pickle. im building an exhaust for my cummins swapped k30 chevy, and i dont want to have to do it again when i upgrade to the WH1E i have. and i dont have the money rite now for injectors. so i was thinkin about puttin the WH1E on now and buildin the 4" down pipe and and exhaust. i will have a fuel pin, 3200gsk, and intercooled. so my big question is will i be able to spool this thing, dont care about performance rite now, ( will it be driveable), or am i just opening a can of worms? i plan on driveing this from NJ to NC quite often and probley b4 i can get injectors. All the info you can give me i would aprechiate. and what injectors would u recommend? this truck is goin to be mostly for towin another truck around and DD.
thanks alot- karl
Old Feb 25, 2008 | 10:25 PM
rebal's Avatar
what ex housing is on it? if its bigger than a 21cm it will be a pig but should spool and turning up the pump will spool it
Old Feb 26, 2008 | 07:38 AM
C/PRD/'s Avatar
Yes, we need to know the housing size. It's stamped on the inside of the exhaust inlet. I would only recommend some 330's or equivilent. Anything bigger and you'll have to watch your guages pretty hard.
Old Feb 26, 2008 | 08:21 PM
Holset 3535870 WH1E is the number, but im no where neer the turbo , but i'll get to it this weekend. what sizes are available on the turbine houseing? i'll try n have my bud look at it for me. thanks guys. i'll keep ya posted
Old Feb 28, 2008 | 08:59 PM
the only number i found on it was 19? think that could be it? also my exhaust flange that bolts to the exhaust manifold is alot bigger then the stocker? what do i do about this?
Old Feb 29, 2008 | 07:53 AM
pwrtripls1's Avatar
the 5.9 ehxaust flange is a T3, that bigger turbo is a T4 flange. They sell an adapter for it or you could spend $50 order the flanges yourself and make your own adapter.
Old Feb 29, 2008 | 03:26 PM
thanks man. well im goin to fab my own. i'd rather build i then buy it anyway. hey do you know if any of the after market offers a smaller turbine houseing maybe a 16. or can i even get one directly through cummins? part number would be helpful.
tristan21
Feb 23, 2006 05:47 PM
G-NOTE
23
Sep 8, 2005 09:25 AM
1ST GEN.
Mar 6, 2005 06:59 AM
racermatt2606
Jul 9, 2004 02:02 PM
Hawkeye
Sep 23, 2003 08:22 PM
