Spindle bearing info?
I am having difficulty locating the needle bearings, which reside within the back of the front D60 spindles (W250) - these bearing are for the outer front axle stubs, which rotate within the spindle. The guy's at the local NAPA can't locate a part #. I looked on the web, and can't seem to locate a part #. Any help would be appreciated!
Billy,
You can pick them up from your local Dana/Spicer Dealer. Check your Yellow Pages. I tried NAPA at one time with no luck on various Dana parts. I ended up going to my local driveshaft shop. Aloha, Matt |
Spindle bearing Dana Spicer # 620063 <------- just bearing.
Spindle bearing kit Spicer # 700014 <----- kit..bearing,and seals. The Timken # for the same kit is SBK3 Sealed power # is FSBK3 Federal Mogul # is SBK3 Cr kits is # is BK3 Hope this helps NoRM |
Norm and Matt,
Thanks for the info! Norm, those parts numbers were a big help, thanks a bunch[guitar] |
No problem BroncoBilly..... I have a few Dana 60 front axles "in stock" around here and I occasionally sell one or use one in a project, so I keep a list of part #'s around.
NoRM |
Originally Posted by MunK
(Post 1646840)
NoRM That makes my mouth water. |
