Speedometer quit
Old Nov 2, 2018 | 07:39 PM
scout4bta's Avatar
Speedometer quit
Odometer quit last year, I can live with that. Last weekend speedo took 5 miles of driving before it started working. Then it bounced around plus/minus 10 mph for 5 miles then it started working correctly. Worked good for 150 miles then quit as I was going down the freeway. Nothing.
Checked VSS have pulsed signel.
have +5v on connector, (orange tracer) and using the black/blue wire for ground.
OD and shifting worked the whole time.
Can anyone think of any other ideas why it's not working before I drop the money on a used instrument cluster.
Old Nov 3, 2018 | 09:47 AM
cougar's Avatar
Check the drive adapter on the transfer case. They are prone to failure. Also check the wiring. I recently had to bypass mine from the VSS to the firewall.
Old Nov 3, 2018 | 10:55 AM
maybe368's Avatar
Cougar is spot on. Mine literally came apart and I was able to put it back together again, still working...Mark
Old Nov 3, 2018 | 06:49 PM
scout4bta's Avatar
Yes forgot to mention I did check the adapter, it's OK. Now what I don't know about is the drive inside the tail housing of the T case. It doesn't spin freely so I'm assuming it's OK.
Old Nov 4, 2018 | 09:00 AM
dodgenstein's Avatar
It usually isn't a case of the adapter in the transfer case spinning, rather the internal square drive rounds out.
Old Nov 4, 2018 | 09:08 AM
scout4bta's Avatar
didn't even think about that, I'll check that out.
thanks.
Old Nov 4, 2018 | 10:04 AM
cougar's Avatar
An easy way to check is remove the adapter and screw the VSS directly into the transfer case.
You can try to spin that square drive with a drill [slowly] and see if the speedo works as well.
Old Nov 4, 2018 | 10:29 AM
scout4bta's Avatar
Two more good checks, thanks cougar and oliver
Old Nov 4, 2018 | 12:03 PM
scout4bta's Avatar
Ran all the tests again and the latest, no response, so I'm going for a instrument cluster.
Old Nov 28, 2018 | 12:52 PM
scout4bta's Avatar
New spedo fix the problem.
I now have bragging rights for high mileage, odometer reads 274K instead of 140K
Old Nov 28, 2018 | 08:11 PM
I am glad the new cluster I sent, solved the problem for you.
foghorn
May 2, 2015 08:16 PM
Darrin F.
Jun 14, 2012 08:10 AM
sabercat
Feb 18, 2009 02:03 PM
raggmann
Oct 29, 2008 01:13 PM
jlebrun
Jul 18, 2007 02:13 PM
