Speedo help
Old Jan 29, 2025 | 07:38 PM
Firstgenforever's Avatar
Speedo help
My computer went out and I got everything wired up except the Speedo I ran the wires one from vss and other to ground can’t remember what colors right now and now it won’t read the right speed and the needle bounces like from 20 to 60 constantly if the truck is moving and I put a new vss on to
Old Jan 29, 2025 | 08:00 PM
Also if it helps my odometer gears are broken so my odometer doesn't work
Old Jan 30, 2025 | 09:37 AM
VSS units come in different gearing. getting a different one will change your speedo reading.
You can use it to your advantage like using a 3.5 gear VSS in a truck with 4.1 gearing, with 37-40 inch tall tires to get the speedo very close to reading correctly. I have done that before several times.
Just randomly replacing VSS units will get you random changes to your speed reading.
It sounds like you have a '92/'93 which runs off a electrical signal for your speedo to work. If it bounces as you describe, it likely due to a bad connection, broken wire or ground.
Jim5870
Jun 19, 2018 08:57 AM
td3620
Jul 5, 2017 03:06 PM
Rick 12v CTD
Sep 7, 2009 04:14 PM
rconrad16
Sep 1, 2008 10:35 AM
rebal
Apr 23, 2005 07:11 PM
