Slack in steering
Slack in steering
My 2wd 92’ d350 has about a quarter turn of play in the steering and I’m pretty sure it’s either something to do with the steering gear box or the steering gear but I couldn’t find anything on the forums about it, It’s been mainly used for in town and highway driving and towing a 30’ camper when if was newer but it seems to be getting worse, anyone have any idea what it might be?
If you have the original steering shaft, along with the rag joint going bad I've also had the bushings inside the "block" (steering box side of the steering shaft, the shaft is basically a rod with a T shape at the end that sits between two rubber bushings sandwiched in the block) go bad and cause for some serious steering slop. They can be replaced fairly easily. But as recommended before a borgeson steering shaft is a good upgrade.
Also before you start throwing parts at it jack the front end up off the ground (both steering tire off the ground) and grab the driver side tire and you should be able to find your steering slop fairly easily.
I had it off the ground last time I changed the oil and I’m pretty sure it’s the coupler going into the steering gear, anyone have the link to where I can get just that coupler without buying the whole shaft?
Napa has just the rebuild kit for box coupler for my steering shaft... my steering box and coupler were completely shot and I was dealing with a serious death wobble
The coupler is pretty straight forward to rebuild ... I had to look at it and get my head wrapped around the idea as I had nothing to go by in disassembly as the internal parts of my coupler were disintegrated
The new steering box and coupler, tie rod ends fixed 90% of my wobble... kingpins and front axle joints are next as soon as I get time and decent weather
SD
SD
The following 2 users liked this post by Berta:
C_conger04 (03-27-2019),
edwinsmith (03-29-2019)
Received 1,637 Likes
Amazon has the steering coupler kit :
if you don't have a napa nearby.
The following 2 users liked this post by NJTman:
C_conger04 (03-29-2019),
You can see all the parts for rebuilding the coupler in my thread, Post #92....I had over 180* slop in my coupler on my donor truck. I
https://www.dieseltruckresource.com/...-305923/page7/
have used a few of the aforementioned rebuild kits ad they do a good job getting things back into decent shape. I like to drill and put a grease nipple near the base of the coupler so you can keep a constant flow of fresh grease into it.....helps it last a lot longer.
NJTman (03-31-2019)
NJTman (03-31-2019)
My D250 with a 1/4-turn of play in the steering is because the center link is shot. (the joint that connects to the pitman arm)
I have some 7 different 75-93 Dodges... oddly enough, I haven't had steering shaft coupler get that bad.
I had an old Dodge van and once I was putting some grease in the steering linkage. At the right wheel joint the grease gun got hard to pump so I applied more pressure and the joint popped off and flopped on the ground.
NOT COOL AT ALL!!!
NOT COOL AT ALL!!!
If a tie rod end is gonna fall off the vehicle, it's actually really cool when they do it in the driveway!
edwinsmith (04-12-2019)
hamilton71801
05-10-2011 05:25 PM
13ALPHA
07-08-2008 11:31 PM
