Silly wiring problem
Old Feb 20, 2012 | 03:36 PM
LPU_911's Avatar
The map and indoor cab light in my truck has a bad ground or something in the circuit. Before, they would only turn on when the passenger side door was open, not both sides. Then one day the driver side door would turn them on as well. I think I went over a bump or something yesterday, and the circuit grounded out, because now the lights won't shut off at all! even with both doors closed. I have just been disconnecting the battery overnight, but how should I go about troubleshooting this? I am not very good with electrical, but am I right in assuming that it's a grounding issue.
Any help would be greatly appreciated.
Old Feb 20, 2012 | 03:41 PM
BILTIT's Avatar
You could pull the bulb instead of unhooking battery in the short term.
Old Feb 20, 2012 | 04:03 PM
Jim Lane's Avatar
First before you dig too deep make sure your dome light is not turned on at the dimmer switch.
Jim
Old Feb 20, 2012 | 04:33 PM
Santaclaus's Avatar
The dome lights are controlled by grounding. There are three points that control the dome light, map light and cargo light. Chances are the wire on your driver's door switch is loose a shortage to ground. You might also check your headlight switch. By turning it all the way to the maximum brightness of the instrument panel lights and just a little more also grounds out the lights. I know the headlight switch seems like a stupid thing but I've seen it be the problem. Just my two cents, Mike.
Old Feb 20, 2012 | 05:54 PM
deanhinsley1963's Avatar
x2 on the door switch grounded out
Mostwanted
Jun 27, 2003 03:57 PM
west coaster
Oct 12, 2002 10:48 PM
