shut down solenoid/ Horsepower
Old Aug 11, 2006 | 06:18 PM
  #61
Originally Posted by BigWaylon
reviving and older thread...
wannadiesel...just wondering why it ran for an hour and a half? could you not just use the shutdown lever?
Greg
I had been flogging the truck pretty hard, so I set the cooldown timer, pulled the key, and went inside. I used the shutdown lever when I came out and found it running.
Old Aug 11, 2006 | 06:21 PM
  #62
Originally Posted by ddog87
I'm wondering to Dave, how is yours holding up with the shaved plunger. Also how far is to far to turn up the pump. I have mine turned all the way in right now.
It's been about a year and the truck shut off with the key today.
I don't know that there is a definite "too much" point. I hadn't touched the fuel screw in a year or so when mine failed.
Old Aug 11, 2006 | 06:41 PM
  #63
ddog87's Avatar
So will turning the fuel screw all the way on cause it to wear out faster. I got some info from a cummings tech friend of mine and this is what he is telling me, that if you turn the screw in more than 2 turns it will fry the pump, any thoughts. Thanks
Old Aug 11, 2006 | 06:43 PM
  #64
It does make the pump work harder on an intercooled truck, but it's pretty rare that guys on this board lose a pump. It won't blow up if you give it two turns. Might eat the shutdown plunger, though.
Old Aug 11, 2006 | 06:55 PM
  #65
ddog87's Avatar
Ya I am now a member of the cable club too But I am going to try the shave plunger method
Old Aug 12, 2006 | 04:14 AM
  #66
frostie's Avatar
At this point in time, we have no before, and after dynoes of running with a solenoid or without. Im still running with no plunger. The bad news is I need to spend a bunch of money on a new clutch to give some HP readings
uncleroty
Feb 1, 2006 06:06 PM
12valve
Dec 25, 2005 01:29 AM
FROGGIE
Sep 27, 2005 04:19 PM
mainer
Jun 21, 2005 05:58 PM
frostie
Aug 25, 2004 12:51 AM
